Question about Kenmore Refrigerators
The water and ice have a funny taste. Is there a
The water and ice have a funny taste. Is there a water filter in my model 596.9535610? If not, what else can I try? I've scrubbed everything and placed baking soda in both freezer and frig. thanks.
ghappliances
  • 126 Answers
SOURCE: water and ice has a funny taste
THANKS FOR YOU QUERY JACK.FIRSTLY DEPENDING ON HOW OLD THE APPLIANCES IS MOST MANUFACTURES USE THE SAME OR SIMALAR WATER FILTER SO THAT WILL BE YOUR BEST BET TO CHECK WITH THEM.NORMALY WEN THE ICE AND WATER TASTE FUNNY I HAVE FOUND THAT IT IS WHAT WE CALL ICE BURN AND THAT IS NORMALY WHEN THE ICE HAS GONE STALE OR IS STANDING FOR A LONG TIME TO SOLVE THAT IT IS BEST THAT YOU USE THE ICE UP AS SOON AS POSSIBLE.HOPE THAT THIS SOLVES YOUR PROBLEM.
Posted on Sep 10, 2008
  • 4 Answers
SOURCE: Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Posted on Jan 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: FRIDGE FREEZER SIDE STINKS
That is your problem.
The plastic supply lines over time deteriorate and wind up causing the water to smell.
Replace the plastic line with a stainless steel ice maker water supply line available at any home improvement center. They are 1/4 inch inside diameter lines and fittings.
They come in 5/10 and 20 foot lenghts.
After you do this run about 2 gallons of water through the water in the door dispenser. Discard the first 3 drops of ice from the ice maker.
Your ice quality will improve.
Posted on Mar 25, 2009
  • 180 Answers
SOURCE: The ice cubes coming from my GE profile
Check the condition of the teflon on the ice maker.  You will probably need to replace the ice maker if the teflon is cracking and getting into your ice.
Posted on Oct 25, 2009
  • 508 Answers
SOURCE: bad tasting ice from the ice maker
I honestly don't know anything about these freezers but if your ice is that bad then i would suggest one of two things is going on
1- the supply line is causing a problem, to close to something that is heating it up or else
2- The filter in the fridge might need changing since it's possible something got into it.
That's about the only suggestions i have for this problem. Hope this helps
Posted on May 23, 2010
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
Kenmore refrigerator model# 70192001 has funny chemical tasting ice
Do you have a water filter, either inline or inside the fridge side? There is nothing in the water lines or valves within the fridge that will contribute to chemical taste. Unless it's just been connected and the line was dirty. It's either your water supply, and if so install a quality inline water filter will help. Some times if the fridge filter is clogged the water flow to the ice maker is restricted and little bubbles get trapped in the ice and they taste off. You should have crystal clear ice. If not get a filter.
Sep 26, 2009 | Kenmore Refrigerators
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Sub Zero 650S with bottom freezer-Ice tastes funny(musty ? taste)
The 650 does not have a filter built into the unit. Any filter would be on the supply line to unit, usually in the basement below the unit, or under the kitchen sink. Do you use alot of ice? If not you may want to empty the bucket every few weeks to let it produce fresh ice.
Jul 21, 2009 | Sub-Zero 650 / O Bottom Freezer...
Ice tastes funny all of a sudden.
you need to throw out the ice. ice gets stale after a couple of weeks , so toss the old ice. also is there something like garlic or another food that has a strong oder uncovered in your refrigerator section? air flow covers all of the unit, both refrigerator and freezer sections. if your refrigerator is not smelly , put an open box of arm hammer baking soda on a shelf in both sections of the refrigerater. if water and ice still taste funny shut off water supply and check the filter at the rear in the lower part of the unit. take off connecter and visibly check the strainer in the water valve,clean it out by removing it and rinsing it under the sink faucet. make sure that water from other faucets taste ok . the only thing left is to flush out the water tank by filling up glasses of water until the water gets room temperature . that's about all you can do short of replacing the water line leading to the refrigerator, although i have never had to do that before. good luck
Jan 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice maker filter
No, they do not. If the ice is old it can absorb taste from the air. You can also buy an in-line filter for your unit. Hope this helps!
Jan 15, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water and ice has a funny taste
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
Jun 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
