Question about Crock Pots & Slow Cookers
When using the grinder attachment it appears that something was too tough to be ground and now it won't work.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 51 Answers
The grinder part is driven by a shaft from the motor, and not only held in place but caused to turn by a 'shear pin' passing through the grinder bit and the motor shaft. The broken pieces of the shear pin need to be removed from the grinder part and the motor shaft, and a new one inserted. A common 'roll pin' of the correct diameter should do the trick.
Posted on Feb 05, 2010
What is low temperature when cooking a slow pulled pork joint
As low as you can get for slow pulled as this is a very tough joint.
May 09, 2015 | Crock Pots & Slow Cookers
Need replacement lid for continential electric skillet
That will be a tough one. Try checking local Goodwills or on craigslist.
Mar 20, 2014 | Continental Electric Ce23721 Elec.skillet...
I have an all-clad slow cooker that won't get any power
Oh thats a pitty these things happens all the time. These devices working under high temperatures, working once and then turn off until the end of time. Advice you to send it to service if you have guarantee. Else somebody with technical knowledge must check where the problem is by using a test light first then treatment begins.
Nov 05, 2012 | All-Clad 99009 Stainless-steel 6-1/2 Quart...
How do you clean the burnt on food inside the base of a crock pot with a removable crock?
I have the exact same problem! I cooked soup that slowly boiled over the edge and burned inside the base. I know you can't soak it and I don't want to ruin it. Help!
Oct 04, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
The handle on my lid came off so I burn myself when I use the crock pot. I bought some good putty/glue and tried to reattach it but it did not work.
What attaches the handle? Does a screw go through the lid and into the handle? I would remove the old handle and make a new one from wood, or possibly a know such as is used for a drawer would work.
Feb 04, 2010 | Rival 38601 Smart Pot 6-Quart
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Broke cover
I have the model#SCV550 5.5 quart
Black lid and crockpot. but I broke the stoneware liner, it fit model #551 and #552
if anyone wants.
1.Glass Lid $ 7+ 5 shipping(ground)
2.Crockpot $10 + 5 shipping(ground)
Dec 21, 2008 | Rival 38601 Smart Pot 6-Quart
My crockpot's cable was damaged from heat.
amy i would try to tell you how to fix this but i would cost you some money to buy all the things to fix it you might try to go to a tv repair shop and see if they could put another cord on it for you they might charge you 5-10 dollars for this k
Nov 03, 2007 | Rival 37601 6-Quart
Crock Pots & Slow Cookers Logo
23 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
