Question about Combi Centre DX - Mango
Combi bolier problem
The heating works perfectly.
The hot water starts running (at any time) when the taps are turned on. However 1 minute later, the water runs cold, and i have to reset the boiler (or turn off and on), to start the hot water again, however the water runs cold again after 1 minute.
Any ideas?
thanks
Simon
  • Anonymous Nov 23, 2008
    I have the same issue,Bgas have beem out 7 times and still havent fixed it.
    Problem Solver:
  • 7 Answers
Either the h/w flow switch or diaphram reqs replacement or the secondary heat ex or (calorifier) is blocked and prevents the heat from leaving the biler to hget to he taps- the heat starts ok but backs up to the boiler very quickly causing it to shut down
Posted on Sep 18, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Hi my vaillant combi gives hot water for only 15 seconds then runs cold turn the tap off, run the water again & gets hot then runs cold some told me it might be the diverter valve can any body help...
yes it is your expansion vessel it sounds under charged to me?your expansion vessel needs to be recharged to 1 bar at least,but check manufacturers instructions it could state different.if the heating is fine and your getting hot water in intervals your diverta valve is moving and working?
Dec 11, 2012 | Water Heaters
I have a Vaillant Combi boiler, (not sure of make, but its 10 years old),the hot water works fine and the bolier heats up the downstairs rads fine, but the upstairs ones have all gone off...have bleed them...
lost pressure raise pressure up 2 bar and bleed the rads keep topping up untill all air has gone from rads do this with the pump off, turn all your rads back on and follow what in said .
Aug 27, 2011 | Heating & Cooling
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Combi bioler heats water but wont heat the
There are 2 Heat Exchangers and 2 Water Pumps on a Combi, at least the one I had when I lived in the UK did.
There is a Thermal Cut Out on both. They look like a Disc, that is Soldered [with provision for connecting the wiring] onto the Hot Water Outlet from the Exchanger to the Pump, to Supply either the Domestic Hot Water, or on the other Exchanger, Central Heating.
If 1 of these fails, the System will start up and when the temp reaches a certain point will trip out the Burner, and continue to Run the Pump until the Temperature drops, and then Stop.
The type I had, had Pumps with a Black front facind nut, this unscrews anti clockwise to release that center, that could be pulled slightly, and used as a Key to turn the Pump Impeller, in the event that lack of use would make it stick, when powered up.
There shouId be a Diagram, inside of the Front Panel, that shows the layout for the whole Internal Water flow, Pipes, Pumps, Safety devices etc. I hope this has helped you.
Regards,DT
Nevada, USA
Aug 29, 2009 | Heating & Cooling
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Combi worcester 240. Plenty of hot water when heating running bot only luke warm when heating off. The pin in diverter valve working fine and ive tested the switch and that is ok !! Anybody got any ideas....
what u need to do is let the flow and return pipes for the heating go cold they are normally the 22mm ones and if 1 gets warm when u run your hot tap then u need a new diverter valve. if they stay cold then u need to see if the boiler is igniting in hot water so turn off the heating and just run the hot tap to see if it ignites get back to me
Jan 31, 2009 | Combi Centre DX - Mango
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
366 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
