Question about Polaroid TDA-03211C 32 in. LCD HDTV
Hello. I just connected my polaroid 32 in LCD HDTV to my computer and there is no sound? I played around with the audio settings on my computer but no luck. How can I fix that? thanks!
  • 583 Answers
You'll need to run an audio cable from your computer's sound card to the TV as well. Depending on your TV's inputs, you will have to get a cable that has a 1/8" stereo plug on one end and either RCA male or 1/8" stereo plug on the other (depends on whether your TV has a 1/8" audio input for the computer connection or RCA inputs.
Posted on Feb 04, 2010
Sound
How is the Xbox connected to the TV?
The TV needs to be told what input is being used for both audio and video
Set it in the TV settings menu.
Apr 12, 2014 | Element ELCFW329 32 Class LCD HDTV - 720p,...
My tv making a screaching sound when we turn it on and no sound and then screaching
try to play dvd if the sound is fine you have loose connection on your cable box reset all connectors.
if the problem still there you have faulty sound board or main board if it is built in..
Nov 11, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
MY 32
Yes, in these sets almost all the audio circuit is on the main signal board which with this model is not likely to be cheap if it can be found.
You have tried to unplug set, a box, or a audio/video receiver and also nothing on any input--leaves unless something odd wrong--audio circuit problem.
May 20, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I have a 32" HD widescreen LCD TV/DVD combo. TDA03211c. When I put a dvd in to play it makes a noise and puts some digital garbage on the screen. Will not play dvds.
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
Oct 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
My Polaroid 32 LCD HDTV - No sound
check that the mute button wasn't turned on
check any external connections for sound are tight or have not cracked or that the cables are not corroded.
ususlly replace with new pair
make sure if playing a dvd your sound is set properly
Aug 02, 2009 | Televison & Video
Setting Polaroid 32" HDTV for 1080i
You must hook up into the hdmi in on tv or use the red blue green video hook ups and it will work switch itself dont forget the red blue audio cables!
Dec 11, 2008 | Polaroid FLM-3225 32 in. LCD Television
Setting polaroid 32" HDTV to 1080i
Manuals for Polaroid LCD TV's are found on the Polaroid support site at http://www.polaroid.com/service/userGuides.jsp?FOLDER%3C%3Efolder_id=2534374302034967&bmUID=1229787329055&bmLocale=en_US
Polaroid TDA-03211C 32 in. LCD HDTV Logo
273 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
