Question about GE JVM1660 Microwave Oven
Louder than normal noise when using and bad 'burning' smell
When i start my microwave oven for a second it sounds normal but immediately (1 second) after starting, it makes louder than normal noise and appears to be functioning when then a terrible burning smell appears; it is working fine otherwise (control panel, light, etc.)
  • jmagno Feb 25, 2008
    thx very much; i suspected that is what it was after looking around the internet; i will not be repairing this myself. One important question as it relates to my situation, could this have been caused by a power surge; we had a power failure several days before which affectd my stove/oven?
  • Anonymous Mar 21, 2014
    electrical smell when it runs---normal?
  • 5,911 Answers
You need to stop using your microwave if it's burning. This is a common symptom of a blown magnetron. Using it in it's current condition is not only dangerous, but it will further damage other components in the high voltage circuit and/or waveguide. In many circumstances, damaging the waveguide renders a microwave non-repairable. A new magnetron will cost you around $100 if you wish to repair this yourself. NOTE: I would not recommend working in or around the high voltage circuitry unless you absolutely know what you are doing. Do not attempt to take any live voltage measurements or operate the oven with any of the protective covers removed or interlocks defeated. Voltage potentials of over 13,000 volts exist and are potentially dangerous. I hope this helps you.
Posted on Feb 20, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 25, 2008
    Could very well have been caused by a power surge. I have seen significatn damage caused by electrical storms too. This may something a home owner's insurance policy may cover...just a thought.
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
Loud boom and burning smell in microwave
Is there any holes burnt into the liner inside the micro wave.? Or burn spots showing.? If there is thow it out. It is not safe to be useing it.It could start on fire. That problem is from when they are not clean out once in a while. End food is burn,t onto the interior liner end grease end oil,
Oct 22, 2012 | Sharp KB6001NS 24 Inch Microwave Drawer...
Does not heat, hot or burning wire/plastic smell. Louder noise than noise than normal.
Sounds like you have a bad magnetron. Not much worth replacing in these over-the-range microwaves except the fuse. Repair will cost as much as a new one and the high voltage circuit of a m/w is not somewhere I would recommend a DIYer to mess around in.
Dec 28, 2010 | Maytag MMV1153A Microwave Oven
We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
Nov 27, 2009 | Kenmore 80412 Microwave Oven
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Feb 28, 2009 | Sharp R-1610 Microwave Oven
Microwave making loud grinding sound
Sounds like a bad magnetron. One test is to set it to run for 30 seconds on the lowest power level. As the microwave power turns off and on, the growling should cycle too. If you or a friend decide to work on it, we have *critical* safety *& disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Otherwise, you can contact GE Customer Relations at 1-800-386-1215 and tell them your problem and they will put you in touch with a local authorized servicer.
May 15, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1660 Microwave Oven Logo
199 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
