Our kenmore elite washer makes a loud loud noise when spinning and the tub has alot of play from side to side when not running. Does this maching have a nut on the bottom holding the tub in place?
    President:
  • 1,515 Answers
You can remove the agitator to see if it has a nut holding the tub on, but from what you are saying the transmission bearings are worn out. Loud noise and side to side play would indicate this. If the agitator does come off you can see if it has a nut that will tighten the tub down. I have never seen one as most are all one section tub to transmission. Keep me posted on what you find.
Sincerely,
Shastalaker7
Posted on Feb 04, 2010
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
My Kenmore Washer Elite HE3, front loaded, makes a very loud knocking noise when it spins ?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Nov 09, 2010 | Washing Machines
Loud spin cycle noise
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 16, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite Oasis that we purchased over 3 years ago started to make incredible noise during the spin cycle, so loud you can barely hear yourself think. We had a repairman from a Service Company...
Yes, Sears repair just ordered one for mine. Entire tub due to bearings gone. Also just over 3 years old and ext warranty ran out in June. Final inspection before warranty was scheduled in June 2010. July the bearings are gone. Hmm wonder how they missed that? Anyway if you call for service, ask about the maintenence plan. Its way cheaper than labor and tub and u have another year for more issues with this piece of junk washer.
Dec 01, 2009 | Washing Machines
Turned washer on side to replace part. now makes loud noise and basket wabbles when spinning. how does triangular part fit under tub? This may be off and not in place correctly. Also two what appear to be...
if you lay it on it's back the 2 sides og the triangle face forward,also look at the pads under the triangle to make sure there good,the pins you see are for shipping purpose only-mike
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
