Nokia 5800 XpressMusic Smartphone Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i m ashish... i hve nokia 5800XM... my phone's some shortcut keys are not working properly...like shortcut menu bar....diller, contact key...call log by green button ..plz help me....
Anonymous
Level 2:
Guru:
  • Expert 212 Answers
  • Posted on Feb 06, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
212
Questions
Helped
71528
Points
591
Hi Ashish
I am having a similar problem with my phone currently, it is a firmware issue that can be solved by doing a factory reset on the phone, however i am not doing it for now, because a new Firmware from Nokia has come for 5800 which is v40.0.005 and it is not yet out for the Indian phones so i am waiting to upgrade to this version.
Meanwhile to access the call log you can try this option, change the home screen theme to contacts bar from settings and then when you press the phonebook shortcut key or dialler shortcut key it would work
After you press the dialler shortcut key and you see the dialler on the phone screen press the green button it would show the call log.
Nokia 3120 Classi Supportive File Noting to Display
Pada program jika dipilih muncul tulisan "Supportive file. Nothing to display."
Untuk nokia 3120 classic, bisa dicoba alternative ini:
-> Pastikan progam yang hendak dipakai sudah diklik "options" atau bisa diatur dulu "application access"! (Supaya program dapat muncul)
-> a. Pilih "menu-settings-display-active standby-active standby mode (on)
lalu pada posisi standby pada shortcut bar pilih "options-select shortcuts-application list-silahkan pilih programya (ditandai)
pilihannya:
done-done-(save change? Dan pilih "yes"
Lalu pada posisi standbay pada shortcut bar, dipilih program2 yang sudah dipilih
b. Cara yang ke 2 bisa memanfaatkan tombol shortcuts:
"Menu-settings-display-my shortcuts-left selection key atau right selection key atau navigation key-application list-pilih programnya
Pada posisi standby, silahkan dipilih pilihan tombol shorcut yang sudah diatur
*Semoga bermanfaat
tip
Nokia 5800 XpressMusic Smartphone Tips and Tricks 1. To bring out the...
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Press*#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
Battery saving Tips
1. Always turn off wireless scanning, Blue-tooth when not in use
2. For those not using 3G, choose your network mode to “GSM” instead of “Dual mode” which will consume more battery. Settings -> Connectivity -> Network mode -> GSM
3. Less Display Light
a. Setting -> Phone -> Display -> light sensor (move the slider to the left)
b. Setting -> Phone -> Display -> Light Time-Out (lesser time to save battery but annoying if too short while you are playing games)
4. Always terminate the application properly that is not using by using Option ->Exit. It might be running background and consuming battery which you don’t know.
Memory Saving Tips
1. Restart your phone if the memory less than 30MB, you could either soft reset (User a dialer and dial 5 * * then call) or hard reset by pressing the power button
2. Use Handy Taskman to close all application regularly or kill application that is not in use.
Camera & Picture tips
1. Some noise could be reduced if set the ISO sensitivity to low instead of auto.
2. When viewing pictures, you could use your stylus to view for previous (slide left) or next (slide right) picture like iphone feature.
Video
For converting video that is high quality to play at 5800, should use the mp4 format as below (All is 16:9 widescreen):
a) Xvid @ 678kbps resolution 480×272
b) Xvid @794kpbs resolution 640×352
c) H.264 @ 512kbps resolution 400×224
d) H.264 @ 550kbps resolution 400×224 (Recommended)
Music tips
1. If you can’t find your songs after transferring from your pc to memory card, go to music player -> Option -> Refresh library
Application Tips
1. Always install your phone theme on the memory cards. This is because if some theme does not work (Christmas tree) then you need to flash your phone.
2. Uninstall your application in proper way. Use Menu -> Setting -> Application mgr. -> Installed apps -> Choose application then option n uninstall
5800 Hard Reset(credit goes to ArunGupta)
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM
on Mar 05, 2010 • Cell Phones
I have nokia 5200 Mobile, my mobile key pad working with Shortcut Example: press 7+end call=Menu press 5=go to inbox How can solve it problem
go to settings and short cut option then see the shortcuts option and remove the shortcuts if still problem do a reset of your phone by clicking settings ->restore factory settings. before restoring take a backup of your contacts .thanks
2answers
How to reflash nokia e55
Hi.
Flashing the phone takes special software, a serial USB lead and can be very difficult to do seeing as the phone is a smartphone.
However you have 3 options.
NOTE: In front of the hash key ( #) there is also a STAR key that people often miss and state that the code does not work.
1.. *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data) Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list. The default code for ALL operations listed here is 12345.
2.*#7370# - Reformat your phone (out of the box, tho keep in mind that most newer nokia phones at least n series, e series and s60 based phones have udp - user data preservation so not ALL data may be lost. still it is a good idea to always do a back up of your stuff.)3. This you perform as a last resort. Nothing else is working.If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button. (the default code is 12345)
3. hard reset - hold the following buttons * (star key), 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons ( for Nokia 5800XM - use the following buttons to do a hard reset, /GREEN/RED/CAMERA keys pressed all at once on power up. this will only work on 5800's that have firmware version 20... and up. ) For Nokia N97 (unofficial version but works) is SHIFT /SPACE BAR / BACKSPACE while holding the power button. Again do not let go until you see the handshake screen.
If these codes are not working the only thing for you to do is contact your Nokia Care Center/Service for assistance.
Regards.
Jun 02, 2011 • Cameras
1helpful
DEAR SIR, TILL NOW I WAS USING NOKIA N 72 ETC. YESTERDAY I PURCHASED NEW SAMSUNG MOBILE, MODEL GT C6112. I AM YET TO FAMILIAR WITH THE NEW MOB. ANYHOW, MY PURPOSE OF THIS SELECTION WAS...
Hi ,
You can keep shortcut keys for this mobile also to open the camera
1.In Menu mode, select Settings Phone Shortcuts.
2. Select a key to use as a shortcut.
3. Select a menu to assign to the shortcut key
Thank you
How to remove the icons or the shortcut keys from the wallpaper in nokia china phone e55??
hi...
please follow the following steps..
1.open 'Menu'------->'settings'------>'Display'------->'Navigation key icon'. Please put this option to OFF.
Your wall pape will not have this navigation key icon in it.
thanx
10helpful
My w910i keypad not working at all.call, end call,menu,cancel, and shortcut key not working.how to fix it...
my w910i keypad not working at all.call, end call,menu,cancel, and shortcut key not working (but num'ric key pad is working properly). can any one guide me to fix it...
3helpful
Touch not working for contact shortcut
Yoou can simply restart your handset sir. ;)
Nokia 6280
hi
sir its a kind of virus you hve to formate your mobile by hard formate here is the way:
turn off your mobile pull out the memory card and sim card and then hold the following keys:
1 call key
2 on pad (3) key
3 * key
and then switch on your moobile hold the keys untill you didnt hear the sound and see the hands animation when the mobile comes on it will be formated automatcaly
thanks
your friend from fixya!
Oct 27, 2008 • Nokia 7610
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
