Question about Wolverine Data (2020) 20 GB Hard Drive
Seeking a power supply, User Guide, and USB cable for Wolverine 2020 20GB drive
  • 163 Answers
Your best place to get your needs is from the company you originally bought the hard drive from.
Hope this helps!
Posted on Feb 04, 2010
What's the voltage output from transformer
hi YOU CAN FIND THE SOLUTION FOR YOUR HUB
Warranty Period : Lifetime Warranty Integrated/Included Cable Length : 1.8m Belkin Pro Series USB Device Cable LED Indicators : 1 x Power LED (Green), 4 x Port Indicator LEDs (Green) Max. Load Per Port : 500mA Package Contents : USB 4-Port Hub, USB Device Cable (A-B), User Guide, Power Supply Power Supply Specifications : 5 V DC 4 A (Provided) Option to Expand/Cascade : Yes, via Hubs of this design (stackable) or other Enclosure Type : High-Impact Plastic Enclosure
Sep 27, 2010 | Belkin ExpressBus Networking Hub
How do I reformat my wolverine Flashpac 7000
Open "My Computer".
Right-mouse click on the icon for the Wolverine drive.
Select FORMAT.
Choose "quick format".
Jul 27, 2010 | Wolverine FlashPac 7000 120 GB USB 2.0...
My Wolverine External hard drive make this funny
Are you sure you have the correct power supply? This can happen if not enough current, as required by the unit, is being supplied to the drive.
Apr 20, 2010 | Wolverine (3080) 80 GB Hard Drive
The USB icon appears; but, cannot access the drive at all. Does not show up as one of the drives. Suspect the drive is toast. Can the drive in the box be replaced with another IDE drive? If so, is...
The Wolverine is a high-speed drive, so try also connecting it to an externally powered "dumb" USB hub. HS spindles may require a slightly higher current and the USB port may not supply it properly.
I have not been able to find the Wolverine's internal HD specs, but the device was reviewed in 2003 and at that date most 2.5" disks were EIDE. While some EIDE drives did have a limitation of 137 Gb of addressable space, this was mostly solved even in embedded chipsets (such as Cypress) by 2003.
So, my guess is that with all probability you can place any EIDE 2.5" drive in the enclosure; if I'm wrong (I think not), the drive will still work and you'll have to repartition it, to only access its first 137 Gb.
Let me know how it goes.
Mar 14, 2010 | Wolverine (3120) 120 GB Hard Drive
2100 WILL NOT WORK, WHAT'S WRONG
What I suspect here is that,
the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Oct 31, 2009 | Wolverine (2100) 100 GB Hard Drive
Cannot turn unit off. Green light on, unit running continually. After downloading my 1.0 GB memory card into the Wolverine, I removed the card (and Sony Duo adaptor). When I tried to turn off the unit, it...
DID YOU USE THE RESET BUTTON ON THE SIDE? Put a paper clip into the reset button. also to read larger cards: get latest firmware:http://www.wolverinedata.com/index.php/site/pages/support/ then reformat using: use http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exeReply
Aug 16, 2009 | Wolverine FlashPac 7000 120 GB USB 2.0...
Loading problem
kinda heath robinson affair this one.
If you buy a usb to IDE adapter, they come with a 5v & 12v power supply.You need to open the unit and connect this to the dvd drive's power.
You'll know it's working if you hear hard drive activity.
The recorder will power down, then just power on and away you go !!
alternativly (not tested) get a ide power cable splitter, but the current might be too much
Jul 11, 2008 | JVC DRMH20 DVD Recorder
Plug and play? doubtful.
Is the drive partitioned and formatted already?
Does it work on another computer?
Is the drive powered via the usb cable, or does it have an adapter?
Do you have any networked drives on this computer?
When it is connected on your computer,
click Start
right click Computer
click Manage
double click Storage
double click Disk Management
Is it in the list of drives in the lower half of the window?
Mar 14, 2008 | Toshiba 120GB USB 2.0 Portable External...
Not enougn power
The limitation is actually imposed by the circuitry of the PC as supplied to the individual USB ports.  What you probably need is an externally powered USB HUB.  You will have to determine how much current your drive draws. An example of a max 1 Amp @ 2X500ma/Port is "7-port USB 2.0 hub" [AP-HUB207]. You can check out the specs here > http://www.mittoni.com.au/usb-20-powered-7port-hub-p-1920.html
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Oct 20, 2007 | Wolverine (2100) 100 GB Hard Drive
Wolverine Data (2020) 20 GB Hard Drive Logo
91 people viewed this question
Top Wolverine Computers & Internet Experts
David Payne
David Payne
Are you a Wolverine Computer and Internet Expert? Answer questions, earn points and help others
