Question about Whirlpool Dryers
LGR7620LW0 Whirlpool Dryer gas no glow and burner will not come on....no heat
  • 572 Answers
Check for the exhaust thermal fuse a white plastic fuse
Posted on Feb 05, 2010
Testimonial: "OUTSTANDING"
Whirlpool gas dryer
Check to see if there is a glow at the burner when you start it up. If it glows then the igniter is good. If not it could be a thermal fuse, bad igniter, flame sensor or a bad cycling thermostat. If it glows then it could be the gas valve coils.
May 26, 2015 | Whirlpool Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
MY CLOTHES DRYER BURNER WONT START UP
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Whirlpool Dryers
Whirlpool gas dryer Model #WGD5530SQ0 not heating properly
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Feb 04, 2010 | Dryers
Installed a new whirlpool gas dryer. no heat.
Well being "new" I'd not suspect many parts being defective other than the ignitor for the gas burner. You can view its operation behind the kick panel below the door. It should glow brightly when your dryer is calling for ignition. It may have been damaged if you had dropped it or very roughly handled your dryer wrestling it into position.
Otherwise i'd suspect that the gas line is still turned off, or a wire loose somewhere, or the heat setting in "air fluff"..
best of luck, and have fun,
ttfn
Feb 01, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
Heat no longer works
Is this a gas model? Does the glow coil get bright orange then go dark? You would want to measure the current on the glow coil if this is the case. It could be a weak glow bar/coil or bad coils on the burner. This all assumes the thermostat is sending full voltage to the burner. Please do not hesitate to ask more questions.
Eric
Jun 10, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool LGB6000KQ1 gas dryer not heating up consistantly and sometimes smells like gas is leaking.
if ignitor is glowing but burner fails to light ck/replace the 2 black coils on valve they will sometimes fail after 1st couple of heat cycles
Nov 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Gas dryer
be sure burner is firing off every time it is supposed to if ignitor glows then shuts off without burner firing replace the coils on burner (2 black round things) if burner ok remove rear vent hose and try load without connected if works ok suspect flattened hose behind dryer or line to outside restricted
Jul 16, 2008 | Whirlpool LGR5636PQ Gas Dryer
Burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Jan 01, 2008 | Whirlpool LGR8648 Gas Dryer
Dryers Logo
215 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
