Question about Kenwood Food Mixers
Our Kenwood km 001 was working fine, turned it off, went to turn it an again - nothing! Any ideas please?
  • ali_roper Feb 06, 2010
    we've done all of the above - no joy am afraid.
  • Kenwood Master
  • 6,993 Answers
check the power cable that connects to electricity. And if its the type of cord that uses fuse, check the fuse if its burnt. Also check the wall plug if current is entering into it.
If you check the wire and you seem not to find any problem, then your Kenwood is have a power problem. May a IC or fuse or resistor is burnt from the inside.
If you do not have idea about tech, then I would advise that you give your Kenwood to a repair to fix the problem for you.
But is you believe you can fix it yourself, you can simply loose the kenwood and check the power panel if your will see any fuse or if the power cord has loosed contact.
You can trace the power part of your kenwood from the power cabe.
Best regards.
Posted on Feb 06, 2010
  • 506 Answers
First things first How old is this unit? If it is less than a year Kenwood will replace it. Now if it is older than a year have you verified that you have 120Vac from the wall outlet? If you have we can proceed with troubleshooting the unit. Any of the following will require some disassembly of the unit. Again I want to stress that If it is under warranty opening the unit may void the warranty so please be aware of this. We need to determine the point of failure. It could be the switch, a fuse or possibly a bi-metal thermostat has blown open.
We will start with the fuse. Start by unlpugging the unit and removing the housing. At the entry point of the AC line there should be a fuse holder. Remove the fuse, if it is a clear glass fuse check the fuseable link inside has it been blown or not? If it is not a glass fuse you will need a ohm meter or continuity meter. If blown replace with correct amperage fuse.
Now for the switch, locate the power swith on the inside. Take a volt meter and measure from ground to the switched side of the contacts. When open you should get no voltage, when closed you will read 120VAC. ( BE CAREFUL THIS IS A SHOCK HAZARD)
Bi-Metal Thermostat.
Locate something that looks like this.
http://img.directindustry.com/images_di/photo-g/bimetal-thermostat-120372.jpg
If you cannot find one there may not be one. This is for overheating purposes.
Lastly here is the manual for your mixer stating the one year warranty. Good luck!
http://www.kenwoodworld.com/Global/Instruction%20books%20(User%20manuals)/Food%20Mixers/88907iss3%20KM001%20to%20KM006%20English%20only.pdf
Posted on Feb 04, 2010
Kenwood KM 28 mixer won't work. Fuse and cable are fine
might need a new switch without testing no one can tell
Feb 15, 2018 | Kenwood Food Mixers
Mixer will not turn on.
Please what model of Kenwood you have ?
if is 901 press the green boton. inside when you up the head.
if with that not working. is necessary check the motor and change some components .
regards
Kenwood Chef Restore
Dec 28, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Sep 23, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood Chef (model no.KM 300)
Hi, check in ebay.co.uk if the seller have worldwide delivery.
or check in kenwoodworld.com
remember for model km only fit A993 and A337
best Regards
May 28, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood Major Mixer
Thank you for your time. I contacted the Kenwood company in England.
Apr 05, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood chef 700w
I think its the control modul that has stoped working ,sadly.
Mar 13, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood chef 700w
I hope you didn't buy a new one, ours stopped last week after 25 years. All that was needed were new brushes for the motor. Anyone with a screwdriver could replace them. 4Kenwood had the parts to me in a couple of days.
Jan 07, 2008 | Kenwood KM305 Stand Mixer
Kenwood Chef Excel smells like smoke
It is most likely a burnt out capacitor. They can be replaced for about £30, but it is not a DIY job unless you know a qualified electrician, there is soldering involved!
PJ
Dec 12, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
73 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
