Mitsubishi Blank Screen w/Sound
I have a Mitsubishi WS-55805 Television and a few months ago my picture went out. I still get sound but I just get a blank screen. What might be the problem?
    Scholar:
  • 130 Answers
The lamp sounds like it may be out. That's usually the first step in fixing a RPTV like this.
Posted on Feb 04, 2010
Mitsubishi ws-48315
Its a V24 chassis---it will blank or turn the picture tubes off for a number of reasons--all self protection. Someone would have to look---I presume when you say no picture you mean no light of any kind on the screen.
If no raster (no light of any kind on the screen) problem could be in Vertical or Horizontal sweep circuits which covers quite a few possible parts.
If the set had for example a blue screen only or is stuck on one input there is always to possible hard reset but that will not cure no raster.
SD TECH
Apr 27, 2012 | Mitsubishi WS-55905 55" Rear Projection...
WS-55805 55" screen that I've had since 2000. Always worked just fine until today! No picture, just sound.
Check Your Rear Projection Light Open Back Cover it a little Door on the back ov your TV Set Possibilty Light Burn Out ....Cause of this Problem Fan Malfunctioning Or The Bulb as to be change for new one ... Type The Brand and the Model ov your TV According To your Model it will gave you a list ov different Light Projector Make Shure You dont Touch the bulb with your bare Hand when you put it On Because those light produce very hi Temperature and cant burn out immediatly or explode.
Sep 22, 2010 | Mitsubishi WS-55805 55" Rear Projection...
I have a WS-55805. Was working great, then suddenly no picture, just audio. When I press the Menu button, I get the menu but I see three separate colors for each menu item. Could this be the lamp, or...
This TV does not have a single lamp but a set of CRT tubes.
If you get menu displayed on wrong clors or colors are not matching then it is either a bad CRT, a bad CRT high voltage power board, or sometimes a problem with convergence board and convergence ICs, however in this last case you usually get no picture and no sound .
You can get service manual from link below:
Mitsubishi - CRT Projection Television - WS-55805 Service Manual
Apr 10, 2009 | Mitsubishi Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Suddenly, Sound But No Picture
that is not and easy problem U need experienced tech to take a look at your TV call a local TV shop
Apr 17, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Screen goes black
If you are willing, remove the speaker grill and the rectangular board behind that and look very, very carefully underneath each of the three picture tubes for evidence of coolant drops on the printed circuit boards. These sets have been known to spill a few drops of coolant onto the boards and this causes intermittent problems such as yours. This is my first direction in your case. Let me know.
Apr 16, 2008 | Mitsubishi WS-55805 55" Rear Projection...
My ws 55805 yr. 2000
check this site first
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
if you dont have this in your set then
check convergance amp ic.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mits ws-55805 No sound no Pictuer
FIRST CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010 IF STILL NO HELP PROBLEM CAN BE INTERMITTENT (TEMPERATURE RELATED) CAUSED BY IC7D04 PART # 275P245010 ON THE DOUBLER PCB THIS WOULD BE A THIN VERTICAL LINE IN CENTER, IF GUNS WERE ON.
May 21, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
