hello... probably your radio connect direct to the battery because usually radio connect to accessory switch when you turn on your car... i dont think this cannot drain your battery unless you will not use your car for 1 week..
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously. Possible causes: The leak prevention system has been triggered. Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Motor brushes, worse case scenario motor complete. Run the following motor test. 1. Put main dial to off 2. Press and hold start button whilst turning dial one click to left (easycare 30). 3. When display show 8.88 or two of the progress light come on, release the start button 4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over) 5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin. 7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault. As suggested brushes or complete motor. Hope this helps
Hi there Now I am urprised. There must be three dispensers in your Zanussi as in my Candy. One is for the main wash another for prewash and the third one for the softner. Look in the manual. Kolbrun
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
This symptom seems unusal as there is, what I assume to be, a self check system that monitors conditions and progress of the start up cycle. If there is an abnormal condition recognized during start up, after a short amount of time there should be a malfunction indicated by the LEDs on the front of the set.
Perhaps the self check system is not able to function. If you haven't tried yet, unplug the TV for a few minutes and try it again to see if a reboot of the controls will help. Other than contacting Sony customer service or a local authorized service company, this is the extent of my knowledge about what to try.
There is a error code check that can be displayed, but only if the lamp will come on. To display the error codes, start with the TV off. Using the remote, in sequence press: DISPLAY, 5, VOLUME - (down), POWER. Codes will then be displayed on the screen when the display comes on. To clear the displayed malfunctions, press 8, then press ENTER. To exit the error check mode, turn the TV off by pressing POWER.
