Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
I have a GE electric range, model jb968tok3ww. The oven heats to the temperature I set but it won't stay on. It goes off without indication. The temperature indicator on the control panel remains at the set temperature but the oven won't heat unless I turn it off and then on again, sometimes multiple times.
4 Suggested Answers
HarryHarley
  • 343 Answers
SOURCE: I'm having trouble with the lower heating element
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Posted on Dec 24, 2009
  • 2841 Answers
SOURCE: WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Posted on Apr 25, 2010
gotgeek2
  • 565 Answers
SOURCE: my ge stove is dead. control panel is out,
The circuit breaker probably tripped. Usually it will be a 2 pole 40 or 50 amp breaker. Turn it all the way OFF, then back ON. Sometimes it's not easy to visually tell if a breaker has tripped, so do it anyway. If that doen't solve the problem post back please.
Posted on Dec 19, 2010
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
Oven is NOT reaching temperature set and the electronic indicator remains at the PRE status. Do I need a new element?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Aug 31, 2010 | GE Kitchen Ranges
OVERHEATING OVEN
Sounds like the thermocouple needs replaced. A continuity check when cold might look good. I suggest replacing it.
Mar 26, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Ge oven top element not coming on when on bake setting
Have you tried to look at your Ovens manual book / guide?
Apr 28, 2017 | Kitchen Ranges
Preheating
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jan 13, 2008 | GE Profile J2S968 Dual Fuel (Electric and...
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
64 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Freddy
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
