Question about Sony RM-892 Remote Control
How to tune in channels 1 - 5 have my sky box and that works well but want to tune in channels 1 - 5 have gone into menu set up but not successful in tuning in channels
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
rockitman187
  • 2559 Answers
SOURCE: cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Posted on Feb 01, 2009
  • 362 Answers
SOURCE: Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 04, 2009
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
  • 325 Answers
SOURCE: have lost the link from sky+ to a second tv which
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Posted on Oct 21, 2009
I don't have an aerial, I have satellite. I hav gone through the tuning several times and called the help desk: no joy. I have connected: Scart Sky box-TV....HDMI sky box-TV
The sky box is the box you use to watch TV The flat panel is just the monitor to receive the picture from the sky box you cannot tune the TV to receive the sky EPG signal Use the HDMI input in the TV menu that the sky box is attached to
Feb 22, 2016 | Televison & Video
How do I tune my TV in the kitchen to my Sky box in another room.
Sky box stuck in Stand By on red light Sky Box Guides faq
Sky Troubleshooting faq
either you have it hooked up wrong or skybox doesnt allow 2 screen use,you may need another skybox
May 14, 2015 | Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
SKY DIGIBOX 2nd RF frequency
your in luck, I work for sky as an Engineer.
Firstly go to the main telly where your sky box is.
Using the sky remote press the following buttons.
SERVICES
0,1,SELECT
go to RF
In this menu I would set the RF channel to 38 and turn the power ON and then down to save.
now leave it on the blue menu screen (sky menu)
go to the other room where you link from your sky box is connected to.
press the tv button on that remote and then select channel 6 on the remote
Then go into the menu for the tv and then to setup. go to MANUAL TUNE/SEARCH with most new tv you can scroll down to were it says C _ _ you can then input your channel number as 38 the same as you setup on your sky box.
Dont forget to save the settings and that should be you. You should be able to see the sky menu on the telly with the link on. (that is why I asked you to leave the sky menu on that way you know you havent just tuned it into your normal terrestrial channels.
The reason I told you to turn the power onto the link was so that you can purchase a Magic eye. This will allow you to turn your sky box over from the 2nd room without having to keeping going to the main tv to change over.
here is a link to a random site with a picture of a magic eye on. you can purchase these from many places or even Ebay. here is the link anyway.
http://www.aerialshack.com/commtel-digital-link-magic-p-815.html
hope this sort you out. If so please leave a thumbs up
Sep 26, 2009 | Televison & Video
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Rf2 outlet from sky hd box
on your sky remote
services
0 1 select
make sure the rf is set to on
Remember the channel rf number,
go to your television the link is to.
go to menu then setup and then manual tune
select the channel you want to view sky on. normally channel 6 on your analogue
then go to Channel type in whatever the rf setting was on your main sky box then press save.
that is your telly sorted out. if you have a magic eye connected at the link end you should see a red led light lit up.
if not remove the magic eye and connect it straight into the back of your sky box RF2
just to make sure that the eye is not at fault.
hope this helps
ill check in a day or two to see if you need more help.
Cheers
Little Dish Fitter
Nov 14, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
