Question about Maytag PAV2300 Top Load Washer
My maytag was set for a med load and filled to overflow and leaking out of the bottom.. this is new..
  • 129 Answers
Ck water level switch and tubing then water valve
Posted on Feb 05, 2010
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytage icemaker just started leaking. It is not overflowing as many of the answers here suggest. As soon as the ice dumps, and the tray starts to fill, the water pours out of the bottom front of the...
Check to see if it is level - left to right and front to back. Make sure the mounting screws are tight. If it still leaks, I would replace the icemaker.
Oct 28, 2010 | Maytag Refrigerators
Overflows with water when filling
It sounds like your fill selector is bad this is the switch that you select small med or large loads. There is a rubber vacume line that runs from it to your washer drum as water fills it puts pressure thru the line to the switch when it reaches the pressure set (small med lrg load setting) on the switch it kicks the water valve off. The line may have a leak or the switc is bad. You can ck the switch by hooking a line to it and blowing air into it with your mouth you should hear and feel a click. Sometimes it will fix its self when you push and pull air out of the switch. If not replace it. good luck
Aug 12, 2010 | Washing Machines
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Leaking from the door
Hi there. Have you started using new tablets. Ours does the same thing if we use certain tablets. Ours is too much soap suds coming over the bottom tray, so If you have filled up all your other fluids and then use a 3-1 tablet it may be producing too much suds. These then overflow out of the door and drip out at the bottom of the door.
Hope this helps! It seems weird I know!
Don
Feb 15, 2009 | Maytag Dishwashers
Washer filling up with to much water
is your printer front loading or top loading?
the prob is in the pressure switch or in the pressure hose, usually the hose is clogged up and fails to produce enough presure to activate the switch to shutdown all solenoid to stop the water from overflowing.
if you can open up you unit you can see a small hose 1/2 " trace the bottom hose until you find the clogged part, you can remove and clean this if not you can order a new one for immediate replacement.
if this is a top loading this is much simplier
Aug 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Our Washer is overflowing through the dispenser drawer
water out of the soap drawer could be a multitude of things, start with removing the drawer and checking for blockage in the pipe from the drawer to the drum, next try turning down the water pressure a little sometimes that can help, or has the machine filled up totally till it overflows, that is a blocked pressure switch pipe, start with looking for the blockage first, work with safety unplug if removing lid etc. rate me if i have helped, thank you
Sep 16, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag PAV2300 Top Load Washer Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
