Question about Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards
Atlas 80.1 .. i have a electical controled valve that sits on top of the valve block (n/s) and i am trying to find the part number . i think it is the load senso / overload valve ? . if people know of any sites i can view a parts book it woould be of great help many thanks lee
    Champion:
  • 202 Answers
Go to part store on web that sells parts for your motor they will haave a breakdown
Posted on Mar 27, 2010
Always exhausting through auto dumps
Depending on type will require replacement. Usually dirt becomes lodged in needle valve assembly so can have go at cleaning.
Mar 31, 2014 | Atlas Copco 15hp Rotary Screw Air...
I hav a 65 f100,motor has been swaped out,i think its a 302,the onley block numbers i c r on the front block pansenger side that reads 2(over)80
There should be a serial number stamped on the block itself in front of the one of the heads (the one that sits back further. With this serial number you should be able to contact a dealer and find out the correct engine size. Older Fords had either a 289 cubic inch, a 302 and a 351 small block which from the outside will all look the same.
Apr 01, 2011 | Ford F-100 Cars & Trucks
Siemens washer dryer model WD12D520GB, what is error code 17?
i think f17 is the code for low water pressure, check the water supply to the machine is turned on and the hose is not blocked or kinked or pinched
Jan 14, 2011 | Siemens Dryers
We have GA18 atlas copco air compressor.The problem is the relif valve opensat 7.6bar.The air starts to blow off from the relif valve and the solenoid relif port.We just wanted to make sure if it is the...
Could be a number of problems, Faulty pressure switch or if it is controlled by an electronicon it could be a faulty k4 relay switch inside the controller. You could have a blocked separator or a faulty mpv valve. If the unit has an integral dryer that could be freezing up and i have had a problem with a load relay bleed off being blocked. If not it could be the unloader valve, One way to check if it is electrical rather than mechanical is to pull the plug to the solenoid while the problem is occurring, if it Carry's on blowing while the plug is off then it is mechanical.
Oct 25, 2010 | ACCO Brands Air Tools & Compressors
Our machine sounded wierd last night and we found out that the water is no longer coming in. And we found a melted plastic medicine cup in the machine. Where do I look to see if plastic is blocking the...
Are you sure it is a medicine cup and not the float cup that controls the water level ? The float is a cup with a rod in the center that goes into a tube sticking up in the bottom of the machine. The rod reaches through the
tub and sits on a switch that controls the electic water valve. it its easy to replace.
Oct 27, 2009 | Maytag Dishwashers
IGNITOR GLOWS, GAS VALVE OPENS & LIGHTS, SHUTS DOWN GAS AND CONTINUES TO TRY TO RELIGHT. RUNS COOL. CONTROL THERMOSTAT GOOD. SAFETY THERMOSTAT GOOD. THINKING THIS IS A TIMER PROBLEM TO THE MOISTURE...
good guess,
but i would check the gas valve coils, they sit right on top on the gas valve, they both open to open the gas valve once you have burn one drops out, from your description, it sounds like your hold coil is bad
and will not HOLD the valve open,
although only one may be bad, I would replace both as a pair, since the bad one does pit extra strain on the good one when the valve opens
so there is no telling how good the boost actual is
since it sounds like you have a good idea of what your doing, you can get the parts at appliancepartspros dot com
type in the model number
and look in the gas control section
hope this help
have a great day
Oct 25, 2009 | Frigidaire FSE748GF Dryer
I have a Shaw Atlas Univeral Remote Control and Apex TV, no code
just looke for the anual on line check the brand web page first but i think for those tvs you have to program it ussing it as if u dont have a code
Oct 25, 2009 | Motorola Mobility DRC800 Universal Remote...
Raymarine St6002 Smartpilot Hydraulic System For Mercury Verado Outboards Logo
194 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
