Question about Gaggenau ED 220/221 Electric Single Oven
Gaggenau Ed 220/221 Error Code F 70
My oven shows the error code F 70 and it doesn't work (not even the light) Switching power off for ten minutes doesn't help. What does F 70 mean? Do you have any suggestions to solve the problem (besides calling a Gaggenau service ingenieur). Many Thanks
raimidu
  • Anonymous May 06, 2008
    i have the same problem....what did you do?what i can do?
  • Anonymous Aug 04, 2008
    reliabilty on these ovens seems rubbish - especially at the price point they sell. Had it about 18mths - broke down after 1 year - wouldn't steam. Repair guy stripped the oven to clean float switch which is difficult to access and had become clogged (the rinse function only flushes with cold water) about three months later had the same problem but cleared it by pouring boiling water into oven which seemed to free the float switch. Now at 18 months I too have an F70 error as described by raimidu and looks like I will have to call out the service engineer again. Not happy!
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Posted on Sep 15, 2010
  • mike_c402
    mike_c402 Jan 30, 2013
    Thanks for pointing me in the right direction. I cant physically take out the oven didnt leave enough water pipe to be able to even get the oven out of the housing. However i have discovered that using a star screwdriver, I can remove the door assembly which allow me access to the underneath panel, which i have dried using a kitchen paper and a stick which mopped most of the water out. Im now giving it a blow dry with my hairdryer to dry completely. One important note **** when taking the door off be careful of the electrical connection which plug in, not to damage them. I will let you know if successful
  • mike_c402
    mike_c402 Jan 31, 2013
    Was totally successful , one other thing is the door mechanism slips down once holding screws are removed. So easier to fix the frame first then the door onto the frame.
MY steam oven error message
F74
Posted on Jun 28, 2010
    New Friend:
Gaggenau. type ED 220110 EHLE D22 MY OVEN SHOWING E 71 ERROR I AM TRYING TO PREPARE. NO POSSIBLE. PLEAS GIVE SUCH GOOD GUIDE TO REPAIR.
bab.asry@gmail.com
Posted on Aug 31, 2015
Our Gaggenau steamoven showed error code F70. Power off for 10 minutes gave no result. Then poored several liters boiling water into the oven. Also took out oven and tilted several times. After 30 minutes F70 disappeared and ovens works perfect again. Now we flush with boiling water once a week.
Posted on Aug 15, 2010
I too have same proble - poor reliability on these units. I had to get engineer out to fix float switch that cuts off steam already - half a day to strip and rebuild. Same fault a second time cleared the float switch by pouring in boiling water to oven (the standard oven flushes through with cold water which does not clear even moderate amounts of grease)
Posted on Aug 04, 2008
4 Suggested Answers
ziraffa
  • 827 Answers
SOURCE: F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Posted on Jan 11, 2009
  • 10 Answers
SOURCE: error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Posted on Nov 03, 2009
Testimonial: "Appreciate the advise, but would still like to know the exact meaning of error code F 20. Thanks."
  • 414 Answers
SOURCE: we have an Gaggenau EB 290 oven and the error code
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
Posted on Jul 13, 2010
Electrolux oven error code f130.what to do?
Hey Luciano, I appreciate your inquiry!
From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
Nov 29, 2015 | Electrolux Ovens
Error code f74
Water pressure switch is staying closed. THe water valve needs to be replaced, or the relay (electrical switch) for it needs to be replaced.
Dec 02, 2013 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau over eb 270 error code f10
hello i m french f10 is a problemn of the temperature sonde that give gou the temperature of your gaggenau
May 26, 2012 | Ovens
Gaggenau oven BO 270 error code E005
We have a Gaggenau BO250/251. It gave error code E005, and after a lot of frustration, we opened the left hand light (NOT the light at the top of the owen) and fiddled a little with the bulb. And voila, the owen worked again.
Stupid design to disable the owen when the light does not work. Bravo, Gaggenau....
May 19, 2012 | Gaggenau EB 270/271 Electric Single Oven
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
Error code F 20 on Gaggenau EB 260/262 oven
Nov 03, 2009 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau ED 220/221 Electric Single Oven Logo
5,157 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
Oloyede Monsuru
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
