Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
I have a ge profile fridge model # PDS22SHRBRSS needing help
I have a ge profile model # PDS22SHRBRSS and a week ago had to replace main board a day ago it began acting up again like before . I bought a mainboard WR55X10942 and instructions said to cut a few wires on my refrigerator ...well i didnt end up doing cause it worked fine do you think this is why the frige isnt working now
  • 291 Answers
Yes, you have to cut the wiring as the instructions stated. Not all the models have to have wiring cut, so read carefully to see if yours is one that needs to have the wiring cut. If it is not, then you have another problem, and you will have to let us know what the origional problem was before you replaced the board. If your model requires cutting, you may have damaged the main board by not doing this. Unplug the refer and follow the instructions carefully and test to see if it works. Good luck, Appliance Specialists.
Posted on Feb 04, 2010
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE profile model # PFS22MBSAWW and about a year ago the digital display for the temperature reading would work intermittently. After some time I realized that when the condensor motor was on, the...
ou need to replace the main control board . in the back pt # wr55x10526 and you may also need the display pwb pt # wr55x10522 .. do the main board first and if diplay isn't working properly replace it also .. mm hope this helped .. feed back lps ..
Jul 10, 2011 | GE Profile Bottom-Freezer Refrigerator...
I have ge side by side model PSS26SGPASS it just thawed out everything in freezer, reading tc in fridge side now, freezer 37 degrees fridge was up to 50 company coming purchased 6 yrs ago help!
I have the exact problem. My unit is 6 years old too - purchased in 2004. I have located, after cleaning the coil under the unit, this is not the source of the real problem. I took the upper cover off which houses the main logic board to find if I flicked the comp relay "compressor" the compressor then turned on. I took amp readings before and after they were .2 without the compressor running and 1.3 with the compressor on. The main board will need to be replaced. Personally I will try to locate the actual relay and replace it on the board if possible.
Sep 17, 2010 | GE Profile PSS29NGS Side by Side...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
Refrigerator keeps freezing up. Replaced defraust heater still froze up in about 4 weeks. Tried to replace main board WR55X10037 WITH WR55X10656 BUT THE NEW BOARD DOES NOT KICK MY COMPRESSOR ON. GE SIDE BY...
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
The fridge is making a constant clicking noice
Had the same problem on my GE bottom freezer fridge. It finnaly died a few days ago. The clicking came from a relay on the main circuit board under a access cover on the back of the fridge. Ordered a new circuit card from GE ($157.50 + ship/handeling), replaced it, and the fridge works great. I have an electronics background but if you take your time and are safe, I think anybody would be able to change it.
Nov 28, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrig MODEL GTS22KPB defroster not running fridge warm/freezer cold
you need part WR55x10552 Main Control board it is embedded in the back wall of the unit with a cover plate about 6"X8" unplug and replace this board ctrls it all
May 28, 2008 | GE Refrigerators
Freezer not working again!
here is link my trouble description:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/2538-clicking-noises-back-ge-refrigerator-2.html
Mar 08, 2008 | Refrigerators
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
409 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
