Linksys Network Everywhere NWR04B Wireless Router (NWR04B-CA) Logo
Posted on Feb 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i name my router and make it secure so no one else can use it. when i connect to it it seems there are no step by step help.
Anonymous
Level 2:
New Friend:
  • Expert 163 Answers
  • Posted on Feb 04, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
163
Questions
0
Helped
32886
Points
474
If you type your IP Address into your internet browser, you should be able to log in to your router and change settings.
You will probably have to provide a username and password.
1helpful
How to put password so the neighborhood couldnt access my dlink router
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank")
Lookup for the options to do the following: -
Next step is to secure it (adding a network security key):
1.On the left-hand side, under Setup, click "Wireless Setup" Click on Setup at the top and then click Launch Wireless Security Setup Wizard. Select your desired encryption method (WEP
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Also, do the following changes: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above steps would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet. Please note down the settings such as SSID Key, User Name/Password and Security as in case you loose this information you cannot recover it back)
You may also download and refer to Page 60 onwards of the PRODUCT MANUAL DIR-625 for further information, if required
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
tip
To Change the Security key or the Network key in your Belkin Wireless Router?
Hi Friends,
Please follow the default steps for all the belkin wireless routers to change the Security key or the Network Key in the wireless network
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Security,it will prompt for a login password,leave it blank and click on Submit.
Step 5:Now change the Security type to either WEP or WPA
WEP:
If You select WEP (64-bit), then you will be able to see 5 small boxes ,in each box in key 1,type 2 numbers in each box only in Key 1,after you have typed the number please make a note of it and click on Apply Changes
WPA:
If you select WPA,then you will be able to see the Preshared Key or Password (PSK),in this place type as thing as you wish,after you have typed please make a note of it and click on Apply changes
Step 6:On your left hand side click on Channel and SSID,now you will be able to see the SSID name,Change it any name as you wish and click on Apply Changes
Step 7:Now go to the wireless Computers and try to connect to the new network name,when you try to connect ,it will prompt for a Network key or Security key,type the password which you gave in the belkin router page
The above mentioned steps are the default steps in all the queries if any customer need to change the security or the Name of your network,you can follow the above steps.It very simple and easy to understand
Regards,
Ayyasam
on Mar 17, 2010 • Computers & Internet
Can't secure D link router
All you have to do is connect to the router and secure the connection follow the following steps: -
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
Let me know if any further clarification/ assistance is required.
CreativeTECH
Im using DIR600 and is not working. Sometimes it will work for only an hour. Sometimes not at all. all lights are orange in color. I dont even detect the router itself even if it's pluged. When connecting...
The following is my solution for similar problem with D-Link DIR300. I hope it would be helpful to you as well.
Reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings would be restored. Please note that, after resetting the router you should be able to see the router and connect to it via LAN Cable of Wirelessly as the router automatic assigns the IP Address and gateway etc. Before proceeding to the next step please make sure that you are getting the signals as well as internet. However, the internet connection would not be secure, which can be done later.
Now, all you have to do is connect to the router and secure the connection follow the following steps: -
In the screen shot below I have highlighted the above mentioned options.
Don't forget to convey your feedback and approciate the efforts.
CreativeTECH
How do i apply security to my wireless connection .. it is set up and working well but is currently unsecured
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router) and lookup for the options to do the following: -
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password "leave it blank")
CreativeTECH
1helpful
3answers
I cant remember my belkin router password to enable me to connect to the internet with my laptop. What should i do?
The easy way to get password is to left click on Internet access bars near time on computer.When box appears showing wireless connections right click on your name connected to.In drop box choose properties then under security click show characters to reveal password.Hope this helps please rate
1helpful
2answers
My husband bought a dlink router (it says dgl-4500 on it) and i cant figure out how to use it to get wireless internet for my new laptop....i have three "codes" he wrote down- a "router pass", a "network...
Router password is the password to access the router settings.
SSID is the network name. When you try to connect to the wireless network on your laptop, you will see this network name.
If your network is secured network then it will ask you for the network key or the password. You need to enter the ' security key '.
Click Here for step by step by instructions
Belkin router
Hi Friend,
When you are tring to connect in wireless it will ask for password,please follow the below steps and get the security key of your Router
Step 5: In this page you will be able to see the security key or PassPharse,please make a note of it and type the same when its asking for security key
Regards,
Aysaam
Security lock on, need to remove.
Try This
Step 1 :Connect Router - Computer ( Wired )
Step 2 :Open RSP by typing 192.168.2.1 on the address bar of the internet explorer
Step 3 :On the left , Under wireless Click wifi protected setup
Step 4 :Leave the password blank and click SUBMIT
Step 5 : Disable it and click apply changes
Step 6 : On the left under wireless click security
Step 7 : Disable it and click apply
Step 8 :on the left under wireless click channel and ssid
Step 9:Change the ssid into a different name And click apply
Step 10 : Connect to this new name
1helpful
I am trying to set up security on my Linksys router WRT150N?
Below are some pointers to secure your linksys router:
- Change the default password of the router. By default it is admin. Changing the default password will prevent unwanted users from accessing the setup page of your router. Click here for the steps.
- Change the default SSID or network name. This will allow you to identify your wireless network. Click here for the steps.
- Disable SSID broadcast. This will prevent other users from detecting your wireless network. Click here for the steps. Take note: You will need to manually enter the SSID on your wireless adapter to connect.
- Enabling wireless security on your router. This will require a security key before you can connect to the wireless network. Click here for the steps.
For additional security to your wireless networks, you may refer to this link.
Hope this helps! Happy Holidays!
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
