Question about Lexmark T632 Laser Printer
I have reset the page count and it still shows 300,000 copies the fuser was replaced twice
  • Official Brand Answer
  • 3,344 Answers
There are two types of counters one is the permanent page counter and other is the Maintenance Page Counter this one is the one that needs to be reset. If you are trying to erase the permanent page count that can not be done.
Posted on Feb 09, 2010
HOW TO RESET PAGE COUNT TO ZERO
The page count on these units is a lifetime count and does not get reset. Larger machines like th P4015 have a maintenance count which is reset when the fuser is replaced.
Aug 08, 2014 | HP Laserjet Printer P2035 P2055 Laser...
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
921 service fuser error
The 921 service fuser error indicates the fuser indicates that the fuser unit failed to reach the standby temperature. This usually requires service. But here's a couple of things worth checking:
  • Unplug printer from power source, replug after 30 seconds. Make sure to plug the printer straight to the power outlet in the wall. Bypass any surge devices or power strips as they can cause low amperage resulting to false fuser error.
  • Check Maintenance kit count. Go to Configuration Menu by pressing Select and Return while powering on the printer. If count value reached 300,000, maintenance kit should be replaced.
If error continues, don't hesitate to contact Lexmark technical support or your authorized service provider for assistance.
Aug 30, 2010 | Lexmark Optra T612 Laser Printer
My paper jams up and crinkles when it gets under the ink cartrige the machine says remove cartridge, I do, I take out the jammed paper click go and it does it again. It printed up to page 45 of 50 and now...
Kindly check the Maint Count in the Configuration Menu by turning off the printer, then pressing and holding the Select and the Return buttons while turning on the printer. Select Maint Count Value. If it reached 300,000, maintenance kit should be replaced. If it's below 300,000, fuser and redrive may need to be replaced.
Aug 10, 2010 | Lexmark Optra S 1650 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the Diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count
screen.
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Lite toner marks on paper
The imaging drum is included in the toner cartridge on this one, so you could need a new toner cartridge. If that doesn't fix it, then you are looking at either the transfer roller or the fuser needs replaced. Workgroup printers usually require a maintenance kit after 300,000 pages printed, fyi. that kit includes feed rollers, a fuser, and a transfer roller. Not sure what the page count is, but that could help you figure it out.
Nov 03, 2009 | Lexmark T644 Laser Printer
Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Jul 02, 2009 | IBM Infoprint 1585n Laser Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Reset page count
Hi bseema:
Hope that this helps you.
Resetting Fuser Life
This procedure restarts the counter that tracks Fuser life. Perform this procedure after
you install a new Maintenance Kit.
To reset the fuser:
1. From the Main Menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life
Oct 13, 2008 | Xerox Phaser 4500 Printer
Lexmark T632 Laser Printer Logo
573 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
