You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click
on wireless settings then enable WEP Security then add WEP code .It is
your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: lost installer/set up driver linksys model wrk54G
You don't need the disk. You should be able to log-in to the web interface of the router at this URL: http://192.168.0.1/
If you don't remember the password, you'll have to reset the router to factory defaults and then log-in with password "admin".
SOURCE: linksys wrk54g setup
Many routers have a hole in them; stick a paper clip in, and it will reset itsef to its defaults. Go to linksys online to get the info you need--it will tell you it's default settings, and you can download the instructions. If you have DSL cable, the router will detect its settings automatically. Remember to encrypt it, or any one of your neighbors can use it to connect to the internet wirelessly. You won't have to bother if you connect through a cable to your pc.
