Question about Microsoft Premium System for Xbox 360
It wont read the disk when u close the tray - Microsoft Premium System for Xbox 360
    Scholar:
  • 130 Answers
You may have a bad DVD-Rom. Try movies and games. If you get red lights blinking, your drive is bad.
Posted on Feb 04, 2010
What do you do when your xbox won't read disks?
The main problem might be a big problem with the disk tray. There might be an faulty wire that has lost connection and if your disk wont event turn on, there might be a problem with the power supply that supplies the cd tray. If the disk opens and closes but doesnt read and wont say tray is in and keeps saying open tray, there might be a small fracture on some of the wires or there is something wrong with the motherboard of the xbox 360. The best way is to buy the warrenty now and send it to the xbox 360.
Jul 27, 2011 | Microsoft Xbox 360 Console
My xbox 360 will not read the disks i put into it. it is like it isn't reading that there is a disk in in the tray. it says open tray then close tray over and over again. it wont spin the disk to read it.
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Or Click here to download repair guide
Jan 04, 2011 | Microsoft Xbox 360 Console
My 360 does not read disc, everytime i place disc in ,it says open tray
I fixed this for me today. I opened the tray, and took the disk out. Just inside in the middle there is a small disk that rotates. I just rotated it a little with my finger to get it moving. Once it started spinning the disk tray closed on its own. I then put a disk in and it started reading it. I guess the piece that moves the disk got stiff and just needed some assistance. Hope this helps.
Aug 17, 2010 | Microsoft Xbox 360 Console
My Xbox Wont Read Disks
Take a can of air and blow some into the drive to be sure there is no dust or debris on the laser.
If after this you still can't get the drive to read any discs, then that means the laser is bad. You can either replace the laser in the drive or the dvd drive itself which is easier to do.
Jun 20, 2010 | Microsoft Xbox 360 Console
How do i fix the disk drive on an xbox 360
http://www.pakgamers.com/forums/xbox-hardware-faq-guides/6157-how-fix-open-tray-error-another-solution.html
ezinearticles.com/?How-to-Fix-Xbox-360...Red...Error&id... -
forums.xbox-scene.com/index.php?showtopic=484726&st... -
OK use those links above i am sure you will find help there.
Mar 25, 2010 | Microsoft Xbox 360 Console
It wont read my disc it sits there and doesnt attempt to read any disc it says open tray how can i fix this?
Ahhhhhh This is a fun one! Ok here is the first thing you should do. Put a disk in the tray and keep in mind the position it is facing. Close the tray and wait for your system to say open tray now open the tray and examine the disc. Let me know if it is in the same position and we'll go from there!
Mar 14, 2010 | Microsoft Xbox 360 Console
As soon as i turn on my 360 the disk tray light wont stop blinking and disks wont read
Listen close and see if you hear the tray motor running. If you do then, most likely, the belt and pulleys that move the disk tray are dirty. Which might also explain not being able to read disks. Here's what to do: Pull the face plate off of the 360. This will NOT void your warranty. Beneath the disc tray (look under and "into" the tray) you should see a gear wheel on your left side. Push eject. Use a toothpick (or similar object) to turn that gear from left to right. Keep turning and the tray should pop open. Unplug (WITHOUT turning off) the 360. Pull the disk tray to full extention and look through the slot in the center of it. You'll see the belt and pulleys. Tweeze the belt out small pulley first clean the belt & pullies w/alcohol. Put belt on big pulley first. Then run a lens cleaner disk when you get it opening again.
Nov 24, 2009 | Microsoft Xbox 360 Console
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
One day i was playing halo 3 and my disk drive starting making wierd, grinding noises and stopped then after the noise stopped my disk would stop spinning and now eveytime i try to read my disk my motor...
This hard disk is a easy fix, You can buy a new one for the fraction of the cost, All you have to do is slip this off the unit and apply an new or even a used hard drive. Here is some links for some hard drives http://catalog.ebay.com/Microsoft-Hard-Drive-120-GB-9Z600001-for-Xbox-360_W0QQ_fifptsZ1QQ_pcatidZ413QQ_pidZ70884347QQ_trksidZp3286Q2ec0Q2em271
you can get some for under 30 bucks. if this information helps please rate accordenly Thanks
May 02, 2009 | Microsoft Xbox 360 Console
Disk tray won't stay closed
i have same problem with mine, if i close the tray quickly by hand after it re-opens,it usually starts reading the disc
Jun 14, 2008 | Microsoft Xbox 360 Console
Microsoft Premium System  for Xbox 360 Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
