Question about NetGear WNR1000 Router
My modem connection wont connect in the set up part?
  • 163 Answers
Apiece of equipment in your house may be interfering with the connection, e.g. Microwave, Fan etc...
Hope this helps!
Posted on Feb 04, 2010
My mw2 game wont connect
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Adsl wont stay on ,quick set up ,says cant find modem
Either the router is not connected properly to the modem, or the modem is not set up properly. First, unplug the router from the modem and disconnect power to both of them. Make sure the modem is connected to its data source, in this case the telephone line. Make sure the company has authorized the modem and make sure it's connected to the phone socket they specified, if they did. You should plug a CAT-5(ethernet) cable between the LAN port on the modem and the WAN port on the router. Now power on the modem. Wait until the modem's lights indicate it has a connection. If the modem doesn't indicate a connection, call your ISP. It will probably be as simple as them sending a refresh signal to it. After the modem finds a connection, power on the router. Your internet service should now be working. If not, try plugging the computer's network cable directly into the LAN port on the modem. If that computer then has internet, your problem is with the router. If the computer still doesn't have internet, then the problem is either with the settings on the computer or there's still a problem with the modem/ISP
Feb 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My router wont connect to internet. i have a valid internet connection. i reset the defaults on the router. it will connect wirelessly to my laptop but wont connect to internet.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the router
ad the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 23, 2010 | Belkin (F5D7231-4) Wireless Router
Dir-615 wont connect
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online through the modem. If your computer is not able to go online through the modem then you will need to call ISP first. If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router. open the set up page of the router and change the settings of the router according to the ISP.
Dec 31, 2009 | Linksys Wireless-G WRT54G Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Internet light on wireless modem is red and wont connect to internet. DSL, Wireless and Ethernet port 4 are all connected with green lights. Wont properly connect the modem.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 04, 2009 | NetGear DG834G Router
WONT TO USE LEXMARK 2500 AD FAX IN CONNECTION WITH
HP knows it has issues. Call them. Most of the time it is due to a setting in the computer. It comes from the factory looking for an analog connection. VOIP is digital. Call HP. Brother has issues too
Oct 14, 2009 | HP Computers & Internet
Router not connecting with adsl modem wirelessly
re-set it and re-configure it ur router then you get it
Mar 12, 2009 | Computers & Internet
My xbox
If your xbox is connected straight to your modem or router, the game console will detect the connection automatically; however, if your xbox can not connect still, I suggest you check on the settings of the modem. Try enabling NAT on your modem.
Changes on the modem can be done by pulling up its interface. The interface of the modem can be pulled up by typing the default gateway of the modem in the address bar of a browser.
** ** DEFAULT GATEWAY can be obtained by typing ipconfig in the command prompt.
Once you are able to pull up the interface, play around on the buttons and look for the NAT?GAMING option and enable it.
GOOD LUCK and enjoy troubleshooting!
Dec 08, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
2wire 270HGV-W probelem
Make sure that your new modem is configured with the correct settings that your ISP requires you to have. Contact your ISP tech support and make sure that the modem is set up properly.
Oct 31, 2008 | 2wire (1000-400108-001) Router
NetGear WNR1000 Router Logo
52 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
