Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Door makes a grinding sound when opening it - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
  • 291 Answers
Very likely you will have to replace the door cams. One is attached to the bottom of the door and one is attached to the Lower hinge bracket. You will have to remove the door and lay it on its front, to get to the cam on the door. Good Luck, Appliance Specialists
Posted on Feb 04, 2010
Front load washer will not spin
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FRT18HS6JS Stainless Steel Top...
Symptom: Grinding sound.
This could be either your drum cartridge or your fuser unit.
Take your toner cartridge out and look right up front where the drum cartridge empties 'waste toner' back into the toner cartridge.  There's a little flap there that slides back and forth on the very end.  Slide it back and see if toner is packed in there solid.  If so, vacuum it out.  Then you'll have to replace that drum.  Sometimes you can salvage them by cleaning out all the waste toner, but usually the gear in back has already stripped and it's no use.
If everything looks fine with the cartridges, it's probably the fuser.  You can buy a new one here:
http://www.acrat.com/xeroxfuser.htm
The fuser is that part of the machine that gets real hot.  If you open the right side door, it'll be right close to the top.  There are usually 4 screws holding it in place.  If you take those screws out, you should be able to hold it away from the machine while it's running (you'll have to cheat the door).  If the grinding stops as soon as you pull the fuser away, that's probably your problem.
Let me know if any of this sounds too technical.  eric AT essonline.us
Oct 31, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
I have a ge sisde by side model#gss25rgma ww. the fridge/freezer is working good, but now not making ice, it has started to make a really loud humming type sound if the doors are left open to long than...
Sounds like a evaporator fan motor problem. However remove rear panel and if slight frost on top of evaporator replace motor if not post back or call professional
Oct 02, 2017 | Refrigerators
Lift door on back will not unlock. Grinding noise
sounds like the door lock actuator is frozen and wont unlock,you will have to get the gate open to replace the actuator,you will have to remove the paneling to get inside the door,then dissconnect linkage to actuator,then make sure linkage to latch is free and not frozen,then double check the actuator while dissconnected, hit the lock/unlock button and see if the actuator moves it should not but will make alot of noise.
Apr 12, 2010 | 2000 Jeep Grand Cherokee
My chamberlain liftmaster works fine but when I open the garage it makes asqeaking grinding sound. what should I do?
the rails on the door frame that the door follows to raise and lower need lubrication,clean rails thoroughly then use a light weight grease and lube the rails and oil the rollers on the sides of the door that follow the rails,also oil the screw or chain that raises and lowers the door from the operator unit,this will make them operate easier and quieter
Apr 09, 2010 | liftmaster Chamberlain Garage Door Opener...
Makes grinding sound when turned on---does not heat---turntable does turn
Grinding sound may be the turntable not sitting properly on its support. Regarding the heat issue, check the door safety interlock switches for proper function.
As you use your oven, open the door while it is running, arcing occurs on the little contacts and they eventually burn. When they cannot make contact, the oven doesn't know if the door is closed or not. Forget what YOU know about the door ... the oven must know and it knows by the information it gets from these switches. Door open, the oven will not turn on the heat.
Thank yo for your interest in FixYa.com
Feb 22, 2010 | Goldstar MV-1501 Microwave Oven
It makes noise during the drying cycles
There are 4 possible sources of noise:
1) Drum support assembly - Open the door and turn the drum by hand. If there is a grinding sound and it feels rough, the roller suppot bearings are suspect.
2) Belt tension assembly - Same test as 1 except if you hear the grinding sound but it feels smooth, check the tensioner roller bearings
3) Fan assembly - this can have bearing failure or get foreign objects in it. Access isusually via the back panel
4) Foreign objects - check for things like coins in the space between the front of the drum and the trim around the door opening
Sep 09, 2009 | GE DBSR453EBWW Electric Dryer
Power door locks dont work right
THE ONLY WAY TO FIND AND TRY AND FIX PROBLEM THAT IS YOU'LL HAVE TO REMOVE THE DOOR PANELS THAT ARE MAKING THE GRINDING SOUND, AFTER YOU REMOVE THE PANEL TRY TO OPEN THE WINDOW WITH THE REMOTE AND THIS TIME YOU'LL SEE WHATS MAKING THE GRINDING SOUND...MY GUESS IS THAT THE GLASS COULD BE OF THE TRACK. AND WHEN YOU USE THE REMOTE THE FORCE OF MOTOR AND GLASS CAUSES THE GRINDING SOUND..
GOOD LUCK.
Feb 05, 2018 | 2001 Ford Expedition
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
59 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
