Question about Dell Vostro 1400 Notebook
I bought new battery for vostro 1400, inserted but computer does not detect it and charge it. I downloaded bios and upgraded. I tried it says, plug in ac adapter and battery while batter already is there. It does not find it. Appreciate your kind help.
  • 1 more comment
  • rkadhikari Feb 04, 2010
    Yes, I have tried many times. It fits well.
    I checked with f2, it says, no battery installed. Underneath it says, ac adaptor = unkown device installed. What to do. It still detects the old battery.
  • Sam Courtney May 11, 2010
    Have you inserted the battery properly?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
Might as well try to go to BIOS it self , restart computer press F2 and try to clear NVRAM or check if the battery was recognized.
-ERNZ
Disclaimer of Endorsement: If the recomendation works for you just refer others to visit this site and let us know your feedback about this. Recomendations on this were purely based on authors experience and trainings.
Posted on Feb 04, 2010
Dell vostro 3500 shows battery connected but not charging and intermittently shoes no battery detected
Instructions
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
http://www.aurabuy.com/cheap-9-cell-battery-for-dell-vostro-3400-3500-3700-7fj92-04d3c-paypal.html
Mar 28, 2013 | Dell Vostro 3500 Laptop Computer (Intel...
Tip
How to solve the "Battery Plugged in not charging"
Battery Plugged in not charging and not detected solution I have a Dell Vostro 1510 laptop, and when i have the battery charger plugged in, the battery icon says "10% available (plugged in, not charging)", and if i pull out the cord, the laptop shuts down straight away. Can this be fixed, and if so, how? I bought this laptop new around 6 months ago. The detail info below:
plugged-in-not-charging.jpg The Battery didn't charge or detect being plugged in also caused by four reasons:
  • 1. The laptop battery failed
  • 2. The Adapter failed (can not charge the battery)
  • 3. The motherboard charging electric circuit failed (many caused by short damage). You can view more info here: Dell Motherboard Problem
  • 4. The laptop bios is too old to recognize the battery
After I checked my battery and adapter and confirm they are good. Then I try to repair it by myself.. My Latitude E6400 battery was fixed by myself.
The first solution :I search in the google: Repairman from another site suggested that while the computer is on and plugged in, to unplug the adapter and then plug it back in again. To check the computer can started charging.
So I remove the laptop battery from the laptop and left the AC cord connected, booting it up on the power cord alone until I was able to boot into Windows 7, at which point I then put the laptop battery back into the computer while it was still on. This worked and while a tad unsafe for most people, I wouldn’t recommend you use this idea unless you absolutely had to, that is, if there was no other choice.
The Second Solution: You can download the newest BIOS from dell.com and then flash the bios. But I do not want to update Bios, So I use another way to make the Power manager system to recognize my battery :)
I open up my laptop Device Manager (usually a right click on your Computer/My Computer) and remove all Dell inspiron 6400 battery related devices from the Device Manager. Then after you’ve done that, right click again and select “Scan for Changes”, which should reinstall the proper services and allow for your laptop to charge again. See the more info in the image below.
remove-battery.png If this also can not solve the problem, I suggest you send the laptop to Dell to repair the Laptop motherboard.
The article Via laptop battery blog
on May 27, 2010 | Computers & Internet
Replaced Vostro 1400 Battery is not charging
You might have a defective ac adapter or power related problem on the system board. Go to radio shack and see if they have a tester adapter (most have universal laptop power adapters and you can try in the store to see if this works). If same issue, most like a defective battery or defective system board.
Feb 15, 2010 | Dell Vostro 1400 Notebook
My laptop dell vostro 1400 not turns on how do i diagnose this
hi
i believe what you are facing is as a result of 2 things, the power pack or the motherboard,since you have tried other adapter..i suggest u try opening up the laptop and perceive for burnt smell,..if u cant do it yourself get someone with a bit of experience to help u with it, but definately you will have to replace whichever is faulty
GOODLUCK
Feb 13, 2010 | Dell Vostro 1400 Notebook
I replaced my bettery for vostro 1400, inserted but does not detect and charge.
Logged on to the support site of DELL w/c is www.support.dell.com and then Update the specific BIOS update for your system so that the battery will be recognized.
ERNZ
Feb 04, 2010 | Dell Vostro 1400 Notebook
My vostro 1400 laptop does not detect the battery
hi, gmotian:i think the battery does't match your laptop,i suggest you buy a new one battery from http://www.adapterlist.com/dell. which is an online shop,exporting various models replacement laptop battery.best luck!
Aug 20, 2009 | Dell Vostro 1400 / Inspiron 1420 - 24X...
HDD not recognized whe installing fresh Windows XP!
Hi...
If your HDD will not recognized during installation you need to check if your HDD is detected. Try to look at your BIOS if it is detected. IF the HDD will not detected you need to replace the cable, try to use the other slot of your SATA or IDE ports.
Regards
ICmanServer
Jul 31, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
I have dell vostro 1400 laptop.when my latop charger is plugged in laptop is charged but as suddenly when i unplugged charger laptop is shutdown no battry is charged what is the problem?
You have either a faulty/worn out battery or a faulty charging circuit.
Recharageable battery have a finite number of charge and discharge cycles and over the years the battery life gets shorter and shorter until it is worn out and won't charge any more.
If the battery is more than 2 years old then the battery is most likely worn out and needs to be replaced.
Jul 18, 2009 | Dell Vostro 1400 Notebook
Dell Laptop Charger, wont charge bat. but keeps computer running.
Hi there.
In some cases batteries tend to not charge up because one of the cells are damaged or drained to the point that they will not charge at all.
In other cases it can be the power board on the laptop motherboard itself which can have gone faulty, the only way to tell is to obtain another battery (preferably new) and see if it will charge the new one, if it does then you know that the battery is faulty, if it doesn't then you will have to take the laptop into a shop to be looked at.
This is the only way you are going to be able to work out which one of the two is the cause.
Good luck and thanks for using FixYa!!
May 07, 2009 | Dell Vostro 1400 Notebook
Dell Vostro 1400 Notebook Logo
164 people viewed this question
Alun Cox
