Question about Cell Phones
My pantech duo will not stop playing the message ringtone. even after i open the phone and begin to reply.. is there any thing that i can do to fix this?
  • 2,069 Answers
For all these solutions, please do a backup first. 1. perform a soft reset. turn the phone off and slide it into the qwerty mode. hold down the "S" and "L" button as u turn on the phone. this will do a soft reset to your phone
If problem persists,
2. Master Reset
IMPORTANT: The device will be set back to factory settings; all data stored on the device will be lost. The device may not be functional for up to 15 minutes after a master reset is performed.
  1. From the standby screen, press Start.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Master Clear.
  5. Enter password, press Done.
    NOTE: Default password is 0000.
  6. To confirm reset, press Yes.
    NOTE: The device will automatically reset and may not function for up to 15 minutes following the master reset.
Regards
Posted on Feb 12, 2010
Ringtones
The phone will only play ringtones applied to its memory. You need to move the tone from the SD card to the phone. First check your user manual for ringtone specifications. It should tell you how big a file you can use.You may have to edit the song to fit.
Aug 17, 2009 | Cell Phones
My pantech duo phone doesnt work anymore!
From the way it sounds, mine started doing this yesterday. Everytime i turn on the phone, theres just a backlight and nothing else. well the only way i noticed to get it to work, atleast until i can get a new phone is, to leave it slid up because it wont do anything if its closed or slid sideways. And while it slid up, I either have to call it from my home phone or recieve a text message. I'm not sure why but that made the screen come on so I could atleast check everything. It doesnt always work but it does most of the time. I hope this helps. Just play with and figure out what it takes to get your screen on. I'm not sure how to permanently fix it though.
Feb 10, 2009 | Pantech Duo Smartphone
Pantech Duo won't let me send Text Messages!
i have had this problem previously. sometimes it would work if i sent a message to myself. other times, i would have to just wait a few minutes, and then try again. also, i have made a call, and only then would my messages be sent. personally, i think this phone is horrible.
Nov 27, 2008 | Pantech Duo Smartphone
Set ringtones for text messages
You all can try this
I simply opened my computer on my pc's desktop, then opened mobile device, then opened mobile device again, and then just copied and pasted the ringtones we had made on our pc for our old motorolla phones into the ringtones folder on the phone, and they are mixed, some mp3 some wav and even some aac, and they all work, then she just went into contacts, and picked the ringtone she wanted for each person. Hope this helps!
Nov 16, 2008 | Pantech Duo Smartphone
Using a ringtone for text alert
Always think carefully about altering your phone's window registry for any reason. If you follow the instructions all should be fine. If you are a complete novice, I wouldn't recommend it, you could seriously mess up your phone. Use at your own discretion.
*WARNING I DO NOT know the extent at which this works ( "How many tones that can be added""How long the ringtones can be"FOLLOW THE INSTRUCTIONS!! I AM NOT/WILL NOT BE RESPONSIBLE FOR ANY DAMAGE CASUED TO YOUR PANTECH DUO BY PERFORMING THIS PROCESS!! Doing this involves tinkering with the phones defaults if you change something that you are not supposed to the phone may not work causing the phones warranty to be void (Solution:If your not sure what your doing DONT DO IT). Before you start make sure all ringtones you desire to be used as alerts for text messages, voicemail, etc. are in the "\My Documents\My Ringtones\" folder. This is very important as you will see. Also make sure all ringtones are short enough (15 seconds MAX) that they will be recognized as useable tones*
1. Download the Mobile Registry Editor (Don't worry it's Free) http://www.breaksoft.com/Blog/Utilities/2005/1/Mobile_Registry_Editor.aspx
2. Connect your Pantech Duo to your Desktop/Laptop and run the registry editor
3. Once your device and has been connected to the Editor open "HKEY_CURRENT_USER" (should be the second file folder down)
4. Open "Control Panel" (this should also be the second file folder down)
5. Click (and only click) "Sounds" (Should be the 15th file folder down *make sure its just "Sounds" and not "SoundCatergories"*)
6. Double Click "All Sounds"
7. In the pop up menu box scroll down to the end of the list of assorted factory tones
8. Put your cursor at the end of the last line and press enter to creat a new line to type in
9. Type in " \My Documents\My Ringtones\ " immediately by the exact name of the file you wish to enter ( EXAMPLE: \My Documents\My Ringtones\342.wow.mp3) MAKE SURE YOU ADD THE FILE TYPE (.wma,.mp3, etc.)
10. Click "OK" when you are finsihed adding your ringtones
11. On your Pantech Duo from the home menu Click Start>Settings>Sounds>Text Message then scroll through the tone options to reveal that tones you added are options and and can be play automatically!!
Reply and tell me if it worked, if it didn't, or if the directions are unclear P.S. have someone text you to double check if it works
Aug 23, 2008 | Pantech Duo Smartphone
How do i get my ringtones from my sd card set as my ringtones?
I got ringtones from my microSD card on my Pantech Duo to set as ringtones by using another phone. I put my microSD card in another phone and bluetoothed them to my pantech duo. When i had bluetoothed all the ringtones i wanted onto my pantech duo, i removed my microSD card from the other phone and put it back in my pantech duo. Then i went to "Settings" on my pantech duo and then "sounds". The first option is "ringtones" so i used the circle button to select the ringtone i wanted and hit "done".
Jun 30, 2008 | Computers & Internet
Pantech duo
hi
you can download the manual form here Pantech duo™
riz.
Apr 30, 2008 | Pantech Duo Smartphone
Pantech Duo
you need to cut a somg below 30 sec and make it under 300kb.put it under thenpantech duo icon in hte active synch and into sound files.
Nov 27, 2007 | Pantech C120 Cellular Phone
Cell Phones Logo
19 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
