Question about Timex Watches
Setting the correct time on Seth Thomas clock.
Have a Seth Thomas 8-day ships clock recently repaired. Repairer told me to intially set the correct time by moving the minute hand in a clockwise motion. For 25 years, I've moved the minute hand in a counter clockwise motion to set the time. Which is the correct technique?
  • 2,334 Answers
Correct technique definitely is CLOCKWISE ONLY. You are unbelievably lucky person if did not damage striking mechanism within 25 years while adjusting hands anti clockwise. If I'd have such a luck, I'd try to play lottery. :))
Posted on Feb 04, 2010
Testimonial: "I was surprised by the answer. I can't recollect where I got the advice to set it by counter clockwise. Will follow you guidance. Thanks"
Have old Seth Thomas Metronome ,only key turn about 1/4 turn.Is that normal for vintage one.
It is not normal. Metronome should wind almost the same as a clock. The cause for this 1/4 turn of a winder is that the driving spring do not unwind completely. That means there are mechanical or oiling issues. Show your metronome to any clock repairer (not the watch repairer) and he/she should be able to fix that.
Feb 27, 2011 | Watches
I have an early 1900 clock that I have to wind. I have noticed my clock stops frequently. I go to wind it and it is tight to wind so instead of over winding I tip the clock to start the ticking and the...
You can not unwind the clock yourself, because this requires proper clock makers tools and skills as well. Clock is stopping because it has not been serviced for a long time and the oil in clock has collected dust particles and getting sticky. This does not let the spring unwind freely and is a problem for all cogs and moving parts. Find your nearest clock repair shgop and ask for cleaning, oiling and adjusting. BE AWARE: If you are gonna try to unwind it yourself, you will damage the clock's movement, but most important - you can even brake or loose your fingers, as the clock spring is under unbelievable tension and once released, it uncoils lightning fast and is sharp as a razor.
Oct 28, 2010 | Seth Thomas Watches
I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
Thanks for contacting FixYa.
I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
http://clock-repair.net/site-map/seth-thomas-clock-repair/
Best regards. Jewel
Sep 13, 2010 | Watches
Why is there two places to wind a Seth Thomas Corsair E537-000 clock? Any description on the proper tension for winding?
Two winding arbours are in clocks with chiming, because there are two separategears in one clock and each one is driven by separate mainspring. Description for winding is: Wind each spring as long as you do not feel significant resistance. As soon as you feel the winding goes too hard - stop winding.
Rate me, please.
Aug 05, 2010 | Seth Thomas Watches
How do i wind an old seth thomas pocket watch? mfg. 1894, montgomery ward model
mcdevito75 here, I believe you"ll need a special winding key to wind your Seth Thomas Clock, Best Bet, look for a small watch repair shop in your area, they may be able to order a key for you, have all info regarding the clock with you. Winding keys may also be on ebay under Vintage Clocks/watches.
Jul 12, 2010 | Watches
Have Seth Thomas Regulator clock...three years old hourly ring tones are out of sequence and time of day: i.e. 7:00PM migh dong five times; 9:00AM migh dong three times etc. Directions for setting time...
Sounds like a strike cam and rack alignment or hang up / sticking issue.
If you have already attempted to follow directions "Many Times" Recommend contacting help in your area.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 04, 2010 | Watches
I can't get the clock hands to correspond with the digital time.
You must set the "Zero" position for your watch. Follow the instructions at this address and your problem should be corrected.
http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
Good Luck
Jun 18, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
414 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Jim Dowell
Are you a Timex Watch Expert? Answer questions, earn points and help others
