Question about Microsoft Windows XP Home Edition
Restart problem windows is not loading it restart all time.
  • Microsoft Master
  • 19,396 Answers
Try pressing f8 on startup, then force computer to start in safe mode. Once in safe mode perform system restore from start/programs/acessory/system tools/
cheers
Posted on Feb 20, 2008
    President:
  • 4,402 Answers
Did you install anything ?
can you go into safe mode?
Can't restart windows 7 on my dell d610, did a format on the hd, re-loaded the windows 7 disc, everything runs great until I shut it down then it won't restart
Recently a put windows 7 on my latitude d610 only problems I had were incompat. Drivers (wifi, sound, graphics.) all were fixed with googling those drivers with windows 7 because this hardware is not compatible with 7 but seeing as it is a restart thing,
Check the drivers u have installed try to see if any need updating or are no compat.
Nov 19, 2012 | Dell Latitude D610 Notebook
How to install windows 7 on aspire t650 desktop pc
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
or
http://100-downloads.com/publisher.php?pb=http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool&dl=727
Microsoft .NET Framework 2.0 must be installed
hope this helps
Oct 15, 2012 | Acer Aspire T650 (AST650UC3601) PC Desktop
Reinstall windows
hope this helps
Sep 29, 2012 | Microsoft Windows XP Home Edition
I have hp compaq 5100 sff 3.2 ghz, 1 gb ram HT technology, I am facing the problem that when ever i switch it on some time it does give display and sometime it just beep for memory error. One day i reset...
I think you have bad memory. Try to press and hold F8 button while booting windows And run windos memory diagnostic
or you can do like this...
Running Windows Memory Diagnostic
To run Windows Memory Diagnostic, do the following:
  1. Click the Start button, type mem, and click on Windows Memory Diagnostic
  2. When the Windows Memory Diagnostic screen loads, click Restart now and check for problems
  3. You computer will restart
  4. The memory diagnostic will run and may take some time (or a ****-load of time depending on your patience!)
  5. Windows will restart and report any errors to you
Jun 29, 2011 | HP Compaq dc5100 Small Form Factor PC...
My computer act like it is coming on then when it gets almost to the end of loading up it starts making noises and says on the windows xp load up page. Then if i do f8 and i choose the option of...
Replace the hard drive. That is the problem. The windows xp is corrupted due the hard drive error. It cannot continue to load on windows. Replace your hard drive.
Oct 15, 2010 | IBM ThinkPad 600X Notebook
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Jan 09, 2009 | HP Pavilion 7965 PC Desktop
System restarts after booting into windows
This could be a number of things.
  1. A bad driver is being loaded when Windows starts. Most drivers are not loaded in safe mode so the problem won't happen there. If you have recently added any new hardware, then locate it in device manager and uninstall it.
  2. Bad memory can cause this. Windows running normally uses memore memory then it does in safe mode. If it hits a patch of bad memory while it is loading, then it can collapse instantly.
There are of course hundreds of things that can go wrong at any time..even brand new components can fail or cause issues.
Start with the 2 options above and see how you go.
Hope it helps =)
Apr 11, 2008 | MSI K8MM-V Motherboard
Windows booting problem
hi sunnyh, when you start up the PC start pressing the F8 key every 2 seconds. A dos like window will load. At the bottom of the list choose, last known good configuration. (win might load the last good configuration) it's worth the try.
If your PC still does not load windows than repeat the above, this time choose, Disable automatic restart on system failure.
This also might allow windows to load (hopefully).
A system that starts going into this restart loop happens for many different reasons. Most common reason was a program that was last installed just before PC was restarted. Second most common reason for restart loop. Added new hardware, bios changes & windows boot files corrupted. If you did install a program, uninstall it. If you were in your bios & made changes, reset the bios. If you flashed the bios, go back to the old bios version. If you added new hardware replace with older hardware.
To fix Windows you may have to reinstall it. Do not run format or you will loose all your data. Even system restore CD's allow for a win reinstall without a format, however if the cd does not allow you to reinstall win unless you do a format. Than windows startup files are too screwed up & you'll have no choice but to format.
All you can do is try the above & cross your fingers.
Mike
Mar 22, 2008 | Gigabyte GA-8SR533 Motherboard
Turn on computer sometimes it goes into Windows sometimes it doesnt
Right Click My Computer, Click Properties.
Click Advanced
Click Settings
Uncheck "Automatically Restart"
This will allow you to see the message that caused the restart.
Sounds like its memory, or the mainboard.
Oct 12, 2007 | Computers & Internet
Microsoft Windows XP Home Edition Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
