Question about Dell Inspiron 6400 Notebook
Motherboard power problem
I opened the system and removed the motherboard after it would not power on and noticed there is something like a small resister or capacitor disfigered or burnt-out around the power source area(where the power suply plugs in) can you tell me what is this that burnt and how can I get it replaced- The system is a dell insp. 6400
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
Those must be the jumpers they were the ones responsible for the connectors on your motherboard . If that had spark chances are the motherboard might be affected.
Advised contact the technical support if the warranty is still up but that might void the warranty if they asked why did you open it . If its out of warranty asked tech support for the part number and asked them to connect you to spare parts dept.
-ERNZ
Disclaimer of Endorsement: If the recomendation works for you just refer others to visit this site and let us know your feedback about this. Recomendations on this were purely based on authors experience and trainings.
Posted on Feb 04, 2010
Dell dimension e510 flashing amber light USB front panel
If you are comfortable around computers, you could try the following to test the power supply. Unplug the cord from the power supply, hold the power button in for about 15/20 seconds, open the case, unplug the 24-pin power connector from the motherboard and jump the Green wire to one of the Black wires, reconnect the power cord and power the system on and if power supply fan and hard drive run, then the PSU should be good. Note: Do not remove any wires from the plug, use a small piece of wire or a paper clip as a jumper. Power supply checks out and the system still does not work, again remove the power cord, hold power button in for several seconds to discharge the residue power, reconnect the 24-pin connector to the motherboard. Remove all the PCI cards, the video card [if applicable], memory, all peripherals, disconnect the data and power cables to all the drives, check that the front panel cable is connected to motherboard, with nothing else connected to the system, reconnect the power cable and power the system on. If you do not get any beep codes or diagnostic lights on the front panel, then it would appear that motherboard has died.
Aug 07, 2012 | Computers & Internet
System shuts off within seconds of turning on and fan starts
Motherboards are designed so that holding in the power button for 4-5 seconds shuts the system off. The On/Off key getting stuck or something shorting the pins on the motherboard that the On/Off switch is connected to can cause this behavior.
Open the case and remove the little two wire connector (usually one red and one black wire) that runs from the motherboard to the front panel switch. Then carefully touch both the pins on the motherboard at the same time with something made of metal such as a paperclip or small screwdriver, remove it as soon as the computer starts to power up. If it still shuts off, you probably have a motherboard malfunction. If it starts normally, the switch needs to be replaced/repaired.
Aug 21, 2011 | Audio Players & Recorders
ASUS P4S533-E. Question : The system intruded, chassis opened or tempered before. Please check the system. What does it mean?
Some computer-cases have a small switch that is "triggered" when somebody removes a side-panel. The trigger sets a flag on the motherboard, to say "intrusion", i.e., somebody opened the case, possibly removed something (RAM, video-card), or cut some wires.
You need to inspect the computer, to see if the "intruder" did anything to your computer.
Then, you can enter BIOS SETUP mode, and "clear" that flag.
Optionally, you can then "disable" that "chassis intrusion" programming.
Jun 01, 2011 | ASUS P4S533-E Motherboard
How to change battery in my 2002 Dell 8200 desktop
Desktops only have a very small battery for maintaining the clock, it will not keep the machine turned on after power is removed.
If you open the side of the desktop (once you've turned it off and removed the power cord), you will see a small coin cell battery on the motherboard (main panel). Generally this is a watch battery like a CR2032, or something similar. You can gently pry this out of the holder and replace it with an identically numbered battery.
Mar 01, 2011 | Dell Dimension 8200 PC Desktop
I have lost the right audio channel on my EVGA nForce 790i Ultra SLI Motherboard. Left channel works fine. I noticed some small surface scratches near the 2nd PCIe slot near the back edge of the board were...
Hard to tell but very likely. If the power was on or the was still holding a charge when the card was removed or replaced it could have something to do with it.Try removing the drivers and re installing them.Here is a direct link to PDF manual for the motherboard.
http://www.evga.com/support/manuals/files/132-CK-NF79.pdf
Feb 15, 2011 | Evga MBM-780IFTW-Q6700 Motherboard
How do you replace the cooling fan of the Dell dimension 2400 desktop computer?
To replace the cooling fan follow these steps:-
You will notice that replacing the fan is not specifically mentioned, but it should be fairly easy.
Open the case as noted in the instructions, follow the power wire from the fan to the motherboard, then unplug the connector from the motherboard, and remove the assembly.
Some of the earlier fan shrouds just lift up and out, but others have tabs to hold them in.
Regarding the fan, there might be two release levers accessible from inside the case, but the one by the PSU can be hard to reach.
It might easier to push the retaining tabs, in from outside, using a small screwdriver, pen or whatever.
The installation of the new fan, is just a matter of fixing the new one in place and connecting the cable.
Good luck, and do rate the solution if got help
Dec 02, 2010 | Dell Dimension 2400 PC Desktop
My sst25 starts hard and stalls...seems to be sensitive to engine position before stalling...stalls when throttle is opened and when just runnung
Had the same problem with my SST25 and after looking further, noticed something rattling around in the fuel tank. The fuel filter had fallen off of the small fuel line (actually the small fuel line had broken). Removed filter from tank and small piece of broken line from filter connector, and re-connected to small fuel line.
Jul 11, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
On replacing a Dell Dimension 2400 power supply, I can't seem to dislodge the P1 20-pin power cable from the motherboard. I noticed that there is a small plastic "nudge" on the 2 narrow sides of the...
On just one of the "long" sides of the power-connector, there is a small "lever" -- press the hinged lever, at the end the furthest away from the motherboard, to unhook the connector from the socket, and then pull.
Jun 09, 2010 | Dell Dimension 2400 Power supply - FREE...
Continus beep is coming but some time system is working properly
I suspect that a lot of dust has accumulated in your system. open up the PC side and by using a blower get all the dust out. Remeber to blow in the Power supply also. Now remove the ram modules and clean their connectors with with the swipe of your fingers but be very careful about static charge, touch your fingers with something metallic earthed to the ground before doing it. also clean the ram slots on the motherboard with a small brush. also if you want you can clean the connectors of other devices like hard drives, cd-roms etc.
Apr 10, 2010 | ASUS P5GC-MX/1333 Motherboard
Acer Aspire 3680. How do I get the back off ?
For AS 3680,
Removed screen.
1. Open the door on the back to remove the wireless antena cables.
2. Open the power cover (remove 2 scews on the power cover).
3. removed keyboard.
4, remove 4 scews (silver scews) that make screen attched the the laptop body.
5. that's all you can remove the lcd now.
For opening the body,
1. Removed all screw on the back, include 1 screw (small scew) under hard drive.
2. removed 3 screws under keyboard
3. removed 1 scew on top side (close to power port), this scews held uppercase and lower case.
4. removed lcd lid cable from board (close to power port)
5. now you can separate upperbody from lowerbody.
6. removed 2 scews from motherboard.
7. removed modem cable, speaker cable, mic cable from the back.
8. that's all, you can removed motherboard+power board.
i hope this help you, good luck
Mar 02, 2008 | Acer Aspire 3690-2196 Notebook
Dell Inspiron 6400 Notebook Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
