Question about Refrigerators
Whirlpool gold side by side door handle is loose.I can't find the way to tighten. IT appears the screws are underneath the rubber gasket, but I am a little wary of tearing it loose without anew gasket.
  • 291 Answers
Most door handles now are front repairable. I can't tell without the model number which style you have, but most units have an insert in the door handle. You have to pry this insert out, to get to the screws for the handle. Some handles actually clip on to the door by sliding the handle up or down to clip it on or off. Good Luck, Appliance Specialists.
Posted on Feb 04, 2010
Door handle came loose .how do i tighten it up`
hello kyler.... Empty out the contents of the door of the fridge. Then pull up the gasket and under that you will see screws. Remove those screws and the entire inside of the door is released exposing the screws to tighten the handle. Joe
Thanks for choosing Fixya!
Feb 24, 2011 | Whirlpool Refrigerators
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
Handle on fridge side is loose
Look at the top and bottom of the handle. There should be a plastic end cap you can gently pry off exposing the screws to remove and tighten the handle.
Oct 04, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool gold side by side with ice and water. The refrigerator handle has come loose at the top. The screws all appear to be in accessible as they are directly behind the door handle.
See if you can unscrew the handle at the bottom, and slide it off the top bracket. Then you should be able to tighten the top screws and re-install the handle.
Jul 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint side by side no dispensor door handle loose
Removing the door gasket would probably reveal screws to separate both shells of the door - warning: door gaskets are expensive and may be hard to find on a fridge that old, so be gentle with it.
JOAT
Jun 17, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
My side by side refrigerator handles are loose (Whirlpool gold)
Hi, Most newer models have a screw behind the plastic cover on the handle. Take a good look at the handle and see if the cover can be removed. It should just snap on. If not, please get me you model # and I can assist you further.
Thanks
Vic
May 14, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Dec 30, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
199 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
