Question about Toshiba Satellite 3000-S353 Notebook
Fit hard drive in Toshiba Satellite 3000-514
How do i fit hard drive in Toshiba Satellite 3000-514. Anyone know of a link for schematics for this lap top?
Thanks.
    Scholar:
  • 151 Answers
Http://www.elhvb.com/mobokive/edwin/laptops/Toshiba/sat&sat-pro/3000/3000.pdf
This PDF will give you the basic tear-down instructions for this model
Posted on Feb 05, 2010
Testimonial: "Thank you very much. It is just what I was looking for. Thank you again."
Where can I find a schematic or instructions to open my toshiba satellite u205-s5067 laptop. I want to clean/replace my fan.
Taking apart a laptop to change the fan is a relatively simple task. Just keep track of where all the screws go and follow these steps:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Hope this helps.
Apr 05, 2011 | Computers & Internet
Can't open casing to fit new hard drive can anyone help
You're lucky, my harddisk crashed. Found this on Internet: - First, carefully take off the plastic part (the one with satellite written on it), starting by one of the sides. - Then unscrew the keyboard (only 4 screws); - Then unscrew 2 screws in the hd case; - And voilá, here is the hd. The four keyboard screws mentioned above aren't the whole story. There are another three outside at the bottom of the laptop, marked "K". And maybe you´ll appreciate this link: http://www.toshibaweb.co.uk/toshiba/satellite/1620.htm
May 13, 2009 | Toshiba Satellite 1620CDS...
How to Replace Hard Drive in Toshiba satillite 1555 CDS Laptop
Typically laptop hard drive replacement is pretty easy in about 95% of the cases.
Here is one link that has instructions for several toshiba laptops.
http://www.bixnet.com/toshiba2.html
Apr 17, 2009 | Toshiba 10GB NOTEBOOK HARD DRIVE KIT...
Toshiba laptops satellite 4090
Hi, The laptop you purchased is an older model. It will use most any IDE laptop hard drive. The drive you mentioned from your Dell will work in it. You will need to pull the hard drive and put the sliders or hardware off the old one on to the new one. Look here for more info on your laptop. Look under portables.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Nov 30, 2008 | Toshiba Satellite 4090XDVD Notebook
Know what kind of hard drive to put in a toshiba satillite 4090
It will If its a laptop sized hard drive , A desktop sized Hard drive will not fit.
How do I physically remove old hard drive for bigger new hard drive?
it is on the end..with two or three screws holding it down..be careful..
Oct 08, 2008 | Toshiba Satellite A75-S226 Notebook
WEBCAM
Use the following link and download utility for your lap.
Try this
Thanks
Iqbal
Mar 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite 3000-S353 Notebook Logo
414 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
