My HD DVD player won't read disks
We have a Toshiba SD-V55HTSU which was working just fine. We inadvertently played a 0 region Pink Floyd DVD which has apparently corrupted our internal software. Now we cannot read any DVD's except our JVC lens cleaner. Toshiba told us to take to an authorized repair shop, the shop says our only fix is to get the firmware disk from Toshiba, who then told us the disk is not available for our model. Can anybody help us - is there anything we can do to salvage this very nice Home Theater that we just inherited in October?
    Genius:
  • 3,422 Answers
I have searched for the firmware but it is not available for your model..
The first thing is try a hard reset by unpluging it for 15min ans then plug it back.Doing a hard reset restores the factory default codes of the player.If this doesn't fix your problem then here are few troubleshooting steps:
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
If still ur problem is not solved then i am sad to say you have to get it repaired and thats the only solution..
Good luck..
Posted on Feb 20, 2008
  • Priya darshan Feb 20, 2008
    Click HERE for the user manual and here are the contact details of toshiba: 800-457-7777
    I hope you are satisfied with my solution ..
    Goodluck once again..
    Brigadier General:
  • 3,614 Answers
How can i help you?
  • 19,396 Answers
Did you try an hard start. It means disconnecting system from power for 30 mins then plugging it back?
  • 1 more comment
  • Ginko
    Ginko Feb 20, 2008
    The firmware upgrade for your model does not seem to be available for a free download on the internet. In any case you should be able to order the disk from Toshiba. If you tell me where you are located I will try to find Toshiba customer service number in your area.
    In midwhile here is manual for your unit, in case you want try resetting international code : http://tacpservice.toshiba.com/ConsumerP...
  • Ginko
    Ginko Feb 20, 2008
    Here is Toshiba page for Europe, click contact, select your country and call them, they should be able to provide a firmware upgrade. If you live outside Europe you may need to browse www.toshiba.com to find your contact number.
  • Ginko
    Ginko Feb 20, 2008
    Let me know if you need further support.
    I will be grateful if you provide appropriate rating for most helpful solution at the end of this session.
    Many thanks
The dvd player says "incorrect
The DVD player is region locked and will only play DVDs from a particular region. The cheap DVDs are probably region 0 and so will work on any DVD player. You can scour the internet for a code hack to change the region (I've had a quick look and not found anything).
Feb 20, 2011 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
Feb 23, 2010 | Toshiba SD-K760 DVD Player
I can't play a disc becouse the region code is incorrect on SD-4000 DVD Toshiba, how I can change the code
Hi, hmm...try this and let me know if it works^_^ Goodluck!
1. Power on the player.
2. Open the disk tray.
3. With the remote, enter the numbers 9 8 7 9 and
then press 0 (for region 0, or multiregion). A prompt
at the upper right hand corner of the start screen should tell you that the player has been set to region 0.
4. Close the disk tray.
5. Power off the player and then power it back on.
Hopefully this will work on all players of this model.
Apr 01, 2009 | Televison & Video
Toshiba HD-E1 DVD Player - Region 1 dvd's problem
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
Aug 22, 2008 | Toshiba HD-E1 DVD Player
I have just bought a Toshiba sd-k770kc dvd player and I can't play region 2 dvd's on it as I can't find the region change code for it. Any ideas
- Power ON
- Open Tray
- Enter Cod : 9879 and 0 For All Region Free ( For A Few Seconds In Uper Right Corner Will Appare : { Now Your Region Is Set To " 0 " } Or Some Thing Like That)
- Close Tay
- Power OFF
- Power ON
Try this it should work ok in making this player region free so you can play any dvd's.
Aug 05, 2008 | Toshiba Televison & Video
Region code unlock toshiba sd 4100
Jul 07, 2008 | Toshiba Televison & Video
Toshiba SD-P1400
what region this is set for now?
May 21, 2008 | Toshiba SD-P1400 Portable DVD Player
Unlock code for Toshiba SD-270EKB
dvd model SD-270EKB
1.power on dvd
2.open disk tray
3.while tray is open press 98790
the last number zero represents all regions unlocked.
Apr 06, 2008 | Televison & Video
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Toshiba HD-A35 region unlock
I am in need to find what an error code is on my HD DVD player. The code is 408 bc 504.
Jan 19, 2008 | Toshiba HD-A30 HD-DVD Player
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
