Question about Maytag Dishwashers
The water is not getting spun around inside my Maytag, everything else seems to be working, but the dished are not getting totally clean.
  • 129 Answers
Ck screens may be chopper propeller kit
Posted on Feb 05, 2010
GSD4200 Will not clean the dishes. All functions appear to be working as normal
Seems like the pump is not pumping water in well or out , it could be clogged or waring out
Dec 27, 2013 | GE Nautilus 24" Built-in Dishwasher
Whirlpool Gold Dishwasher- bowls in center of top rack are full of water, bowls in corners have almost no or no water in them and dishes on top rack are dirty. Dishes on bottom rack are clean.
First try running a cycle of "Dishwasher Magic". You can find this at Walmart for around 5 bucks. This will clean and condition the inside of the dishwasher and the inside of the pump and motor.
If this doesnt help...and the plastic and/or metal components in the dishwasher seem to look and feel intact..this would lead me to believe there is an issue with the pump and motor. These are sold as 1 unit or as seperate units depending on the model. Changing it is simple if you know how to dissconnect and reconnect a dishwasher. Take into consideration the age of the unit, the cost of the part, and the cost of a total replacement.
Oct 29, 2013 | Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
After a wash, my Quiet Series 100 Maytag washer has fine grit all over the inside of dishes. Is there a filter somewhere I should be cleaning?
Try changing the brand and type of detergent that you are using. Some seem to work better under hard water conditions. Hope this helps.
May 07, 2010 | Maytag 24 in. MDBH950AW Built-in...
Is there a product on the market that I can use to clean the inside of my Maytag dishwasher? We have very had water and there seems to be a hard crusty film build up inside. The dishes are not as clean aas...
Hello
I have used Vinegar myself.
just placed a large cup full in the top rack and ran it through with no dishes in the dish washer.
and once the dishwasher was clean we used a small amount of vinegar to clean the stainless steel bowls and silverware and glass.
I have also used this product:
http://www.reliableparts.com/product/Glisten-Dishwasher-Cleaner-1476390/Dishwasher-Accessories-461418
and it also worked..... although there are restrictions ( no stainless steel dishwasher tubs ).
I found this site for you:
http://www.mrscleanusa.com/tips/clean-dishwasher.html
I found this product for you as a bonus although I have no personal experience with it
http://www.smallwonder.info/?gclid=COyUycvLgaACFQwNDQodKm_Zjw
Feb 20, 2010 | Maytag Dishwashers
My dishes are not clean and cloudy
After you have removed the filter and cleaned out any debris, clean the inside of the dishwasher with white vinegar by filling a bowl or large cup with white vinegar and placing it on the rack and running a short cycle with no powder inside.
Use a name brand powder (Cascade or Electrosol) rather than the ultra-cheap powder. Never use gel or tablets in any dishwasher.
If problems continue, you almost certainly have a failed heating element. Replacing the element yourself is not tremendously difficult if you are handy and promise fo disconnect the power before you begin. Otherwise, a service call is the next step.
Mar 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Loud noise maytag dishwasher quiet series 100
Hi All,
I have had a Maytag Quite Series 300 for some years now and have done basttle with it on may occasions. I now consider myself somewhat of a veteran, although by no means a repair expert!
Grinding Noise: From either a clogged/blocked impeller or not enough water getting to the impeller.
For a clogged impeller, it is fairly easy to disassemble the washer to get at the impeller to remove any debris or blockages.
For not enough water it can be a number of things. First of all, you will notice that the noise lessens if you add a jug or two of extra water. This is because if the water level is too low, the pump impeller will get some air mixed with the water & this is LOUD! Now for the causes:
Float – If the float gets stuck in the wrong position (debris or water deposits), it will not fill enough.
Float Set Wrong – Seems thats some of these dishwashers have the float set a little too low to let the dishwasher perform without grinding. A few pennies attached to the float with a rubber band seems to help here. Don't go too far or you'll flood your kitchen!
Timer – Some folks have mentioned that dishwashers that fill on a timer will not fill enough in the allotted time, if the water pressure is low. While this is true, I have looked over the electrical & parts diagrams for the QS300 and I do not see a timer listed anywhere. Also, the wiring diagram appears to show that this dishwasher only uses the float to achieve the correct water volume. I could be mistaken here.
Note that in VERY hard water areas (like mine – TDS of 850 hardness or 49 Grains), the plastic fins on the cover of the impeller get very choked up with water salts and this can impede flow, leading to a low-water symptom, when in fact, there is plenty of water.
Dishes Not Cleaning:
Poor Water Flow – See above, all the above items will negatively impact dish cleaning.
Poor Q uality Detergent – After trying them all – Yes, all – Do not use cheap detergent. Buy the brand names: Cascade or Electrasol work well. I have found that by far, the little packs work the best. We found that the liquid works second best and the dry stuff really isn't up to the task at all, no matter which brand.
Spray Wands Catching – We found that our lower spray wand was catching on the bottom of lower dish tray, so I very slightly bent down the legs that the wheels mount to in order to lift the dish tray/basket a little and give the wand a little more room. This worked well.
Spray Wand Nut Too Tight – The factory seems to send the dishwasher out with the nut on the bottom spray wand tightened a little too far. Loosening this a little bit lets the bottom wand rotate much more easily.
Top Spray Wand Not Meeting Receptacle – The top spray wand is attached to a pipe that mates with a port (well, one of two ports, depending on if you have the top rack in the “Upper or “Lower” position). The pipe seems to have a tendency of missing the port. A well placed elastic band will help here. Note that on our dishwasher, by the time the first elastic band wore out, the pipe had been permanently moved to the correct position by the gentle pressure.
Tines/Dish Holders On Top Rack Falling Over – The tines (metal spikes) that hold dishes on the top rack fold down by design. Issue here is that they do it sometimes during the wash, causing the dishes to fall over and block the spray. A few well placed rubber bands help here as well.
Water Salt Buildup – If you live in a very hard water area, you can still get clean dishes from yor dishwasher. We do and we have VERY hard water. Buy a gallon of vinegar once a month. Pour this into a clean dishwasher. Turn it on so that it runs for 2 minutes to circulate the vinegar. Open the door & let stand over night. Close door & finish cycle. This will cut down significantly on the hard water salt buildup in the washer.
It's A Maytag – Sorry folks, it's true. I have learned (after purchasing the dishwasher) that Maytag has run into financial difficulty in recent years and has reduced build quality to save money. If you got suckered into buying one of these, you will very likely never buy one again. My opinion is “Do not by Maytag.”
Hope this helps someone!
Dec 31, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Dishes not cleaning
it may be hard water or some other minerals in your water. there is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Apr 01, 2008 | Dishwashers
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
41 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
