Back to:
Tags:
IBM 1200 watt for Bladecenter  - Qty2 x Fru 49P2045 -  Power Supply
Wants to get more explanations.
posted by CHIEFOBEN on Feb 20, 2008
Sir,
I am a cameroonian, age 24 and a worker with an NGO called LukmefCameroon as a System Administrator. I have so many problems on how to set jumpers on Motherboards, Hard drives, CD-ROMs etc so i want you people to help me with diagrams and notes that could help me.
You can contact me by email; joseph@lukmefcameroon.org.
Waiting to read from you.
Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 25, 2008
Helpful (85)
RADICALpcs
Rank:Master Master
Rating: 91%, 26 votes
different motherboards and hard drives use different settings for each application unless U work on identical machines with identical parts. MAXTOR,SEAGATE ( old er 1's ) QUANTUM,CAVALIER,IBM deskstar, etc use different jumper settings depending on the application.. EXAMPLE older maxtor hard drtives set JUMPER 50 to run as a master with no slave present jumper 50 is the jumper closest to the ide cable ..
System administrator eh ?? allrighty then ..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Wants to get more explanations.:
I don't want to Accept this solution
Can you Help with these System Power Supplies problems?
i am on aol and i keep getting disconnected and its always...
I just read your solution to a problem that I have been...
i have a qdi motherboard and i put a 200 watt power supply...
I bought the Pinnacle Studio Version 10.6 but was unable...
Does Anyone know where i can buy spare parts in big...
Loading problems.
Repair Service
Find System Power Sup. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
