Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp copier AR5316
MY SHARP COPIER AR5316 IS SHOWING ERROR CODE 2H
  • 2 more comments
  • karege May 05, 2008
    my copier is showing me this : error code2H
  • Kabarows May 12, 2008
    i have same model but it code h4 or 4h pls help
  • ahmedsolanki Sep 06, 2008
    pLEASE HELP ME MY SHARP AR 5316 MACHINE WAS NOT START
    BECAUSE IT SHOW ERROR (2H)
    PLEASE SEND THE SOLUTION
    REGARDS
  • Anonymous Dec 14, 2008
    Bonjour, j'ai le même problème, mon copieur affiche H et 4 mais ne marche pas.
    Merci pour votre aide
    President:
  • 2,072 Answers
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
If this does not clear the problem the fuser will need replaced.
Posted on Feb 21, 2008
  • 148 Answers
The H2 may also be that one of the connectors for the fuser is loose or not connected, there are 2 from the fuser unit.
Posted on May 27, 2008
  • 29 Answers
If this does not clear the problem the thermistor will need to replaced.
Posted on Feb 26, 2008
My copier machine sharp AR5316E shows error message 2U, please what is the solution?
remove the catridge to the machine and then insert it back. if it still display the same information the catridge might be damaged need to be replaced.
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error f2 in sharp copier AR5316E
F2 sub code 00 - Toner Sensor problem, ID pattern reading error. You may have to replace the drum unit or have a tech clean the toner sensor
Mar 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Mar 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Mar 07, 2009 | Sharp AR-5320 Black and White Copier
Ia m using Sharp Ar5316 it showing Error E7 11
E7-11 is 'shading error', probably your optics need a clean, take the glass out and clean the mirrors
Cheers
Nov 29, 2008 | Sharp AR-5316 Advanced Digital Imager...
Unit ig giving a 2H error code
the problem is h2 not 2h you need to replace the thermistor or try to clean it by an ordinary cloth
Jun 17, 2008 | Sharp AR-153E Copier
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
513 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
