Question about Baby Lock Eclipse Serger
How to adjust stitch width on babyloc eclipse lx serger
  • 32 Answers
Here is the info about this serger from the baby lock's website. It says the stitch length is a dial. I couldn't find the manual for download, but they say they stand behind their products with support. I would follow the customer support link at the bottom of the page and request a user manual. It looks like they sell an instuctional video and optional workbook too. Might be worth the price to help you get the most out of your seger. Hope this helps!
http://www.babylock.com/sergers/previous-models/eclipse-lx/
Posted on Feb 05, 2010
I bought a second hand babylock eclipse serger, the pproblem is the width sticth adjusment is stack, how do I slove it.
Just guessing the machine may need cleaning and oiling. Consult the owner's manual. Sergers usually require frequent oiling (more than sewing machines) because of the speed and complexity of moving parts in a serger. Apply 1-2 drops of fresh, good quality oil for your machine--some brands use a specific weight oil.
If in doubt, take it for service. It could probably use a very good check-up by a professional anyway. At least then you will be starting out with a tuned up, working machine.
cleaning your serger (avoid using compressed air as sometimes it will force lint and debris farther into the machine!)
Cleaning Your Serger
Serger Cleaning and Oiling
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
Since your issue is with the stitch width function, you may want to focus more on that mechanism and work at getting it released. Sometimes applying heated air from a handheld hairdryer will loosen stuck mechanisms.
Jun 10, 2016 | Baby Lock Eclipse Serger
Pushing material away, but still overlocking
It is difficult to tell what exactly is happening with your serger.
First thing--make sure you RAISE the presser foot BEFORE you thread any of the threads. This releases the tension disks so the threads will seat properly. You may need to remove all the threads and rethread from the beginning, making sure you thread each in the proper order. Start out with the thread tensions set at the ideal setting--usually the halfway point between the high & low numbers. From there, you will adjust them to even up the thread tensions.
Are you actually trimming off some of the fabric as it is stitching? If so, you might try increasing the cutting width (moves the cutting edge further toward the right) so that there is more fabric caught within the looper threads. It also appears that the looper tensions may be too loose. Try tightening the upper and lower looper tensions so less of the thread loops don't fall off the fabric's raw edge.
Make It Handmade Understanding Your Serger Features
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Meet Serge Beginners Guide To Using an Overlocker Serger
Using Serger Learn to Use Your Serger to the Max
Bernina 700D Serger 8 Cutting Width Knife Adjustments
Dec 30, 2015 | Sewing Machines
What is the difference between a baby lock sx elcipse special edition serger and sx eclipse serger?
# of threads and # of different stitch types?
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 24, 2014 | Baby Lock Eclipse Serger
I have a Babylock Eclipse serger..while sewing with it the machine jammed up and I cant get it to sew. It sounds like its stuck or motor is jammed..I just hear a small hum when I press the pedal.
A serger does not have a bobbin,they use loopers instead to form a chain stitch. I'm very familiar with the baby lock and they are a simple machine. Email me and I will try to guide you to the solution, chances are it not an adjustment problem but a dry feed cam. my email is rtarkington2@cfl.rr.com
Jan 25, 2014 | Baby Lock Eclipse Serger
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
How do I change the stitch width on my Bernette serger?
You move the top blade to the right to trim less so stitch forms wider and use left needle. Or both needles for 4thread seam which is more for knits. Blade has a knob usually to adjust it's position. You should test on scraps of your fabric as the weight of the fabric will also determine width of the seam. Adjust top and bottom looper tensions to encase cut edge neatly.
Apr 23, 2011 | Sewing Machines
I was given a Huskylock 430 serger and need to know if someone can tell me the correct tensions.
There are really not any #s you can set to give a good stitch. You have to just use the #s as a guide. Most sergers from the factory will give you something decent around 4 across the board. Start there and make slight adjustments as needed. It also depends on the stitch and type of material used.
Aug 17, 2009 | Sewing Machines
I have a baby lock imagine machine. I'm sewing with streatch velvet, and the stitches are off the fabric, or the loopers are too loose. I tried tighting the looper thread fine tuning screw, adjusting the...
Stretch fabric is made for using the differential feed on your machine, sergers love stretchy things. Try widening the stitch you are using and turn your differential feed down one notch to allow the machine to get a good grip on the fabric, you may need to bump the differential feed up more if it still doesn't stitch nice, keep trying on a piece of scrap fabric of the same as you are using until you are happy with the stitch.Another solution is to put some lightweight tissue paper under the seams and then tear it off after you have sewn the seams, this works but will dull your blades over time.
Oct 30, 2008 | Baby Lock Eclipse Serger
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
Tension factory settings for Baby Lock serger Model BL400
The factory settings are 4, 4, 4, 4, and width at M. Hope this helps.
Mar 03, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
293 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
