Question about JVC AV-48WP30 48" Rear Projection Television
Have a JVC av-48wp30 I replaced convergence ics and resistors with Tv worlds repair kit I resoldered the whole convergence board and still it sometimes has a picture but most of the time it has greens line horz or the color bars verticle or the green tube is the only one that comes on and it is flickering on the top half of the screen the blue and red are off any ideals
  • 8 more comments
  • Brian Lange Feb 04, 2010
    I checked solder connection with a magnifing glass there were no visalble spots I did resolder most of the board but not the surface mounted stuff no hot spots on the board either were do you buy a new convergence board if you want to replace it thanks Brian
  • Brian Lange Feb 05, 2010
    ok I'll back up a bit I've worked on a few tvs before and been doing car stereo installs as well as remote car starters and some on board repairs I went to a tech school and work for a company for 15 years that did electronic repair before I went on my own so I've been around the pc board stuff and have done plenty of soldering and came run a volt/ ohms meter so what I first did was ordered the stk - 110 from mcm electronics I put them in and nothing changed so I ordered the kit from tv world I did replace the stks again as well as the 12 resistors that came with the kit I checked the resistance value of all 12 that I removed and they all check ok but I replaced them any way but I still have the same problem I believe I had the picture work twice when I was working with it - It has an excellent picture when it does work so the resistors that you mentioned in the last repley are they part of the 12 resistors I've already replaced if not were are they located and what tolerence do they need to be
    thanks again for you help Brian
    those resistors you talked about I found them on the schematic that tv world sent along when they sent the stks and the twelve resistors so I better go ohm them out to see what they are and no I don't know how to do the convergence for sure I am able to move the cross when I go to the menu section for convergence with the remote so I guess I'll go check those resistors first thing tomorrow and see what they test if there is any thing else you can think of that I should check please let me know I 'm excited about this help I do think there is something on the convergence board that is shuting down and hopefully one of those resistors is doing so thanks again Brian
    Hey wow that pw convergence board (ssb-5051a-m2) at that Encompass Parts Dist. its only 75.00 dollars that would be alot cheaper and simplier than doing the piece by piece replacement but I guess I didn't know that till know so I let you know how I come out on the other resistors you told me to check thanks again for you time Brian
  • Brian Lange Feb 09, 2010
    I have just rechecked the resistors on the convergence board and re- resoldered the board again and still the same thing plugging the tv in and than unplugging it and once in a while it will come on and the picture is very good it will run like that until it is shut off and than it may come on correctly but most generally it does not and than you have to play the unplugging and plugging in game it acts like maybe a weak capacitor or some thing like a voltage regulator just not getting the correct voltage at start up or or or I don't know any help would be appreciated thanks Brian
    rylee still haveing problems with the jvc tv I resolded the convergence board and replaced all the resistors and both stks that tv world sent with the kit and still the tv will sometimes come on and work great and the nent dozen times you try it comes up with the color bars on the screen and 0r the green tube being the only one flickering on acts like a incorrect voltage in start up and when it changes a little bit it will start up and work fine untill it is shut of than it may start up fine but most generally it doesn't any thoughts Thanks Brian
  • Brian Lange Feb 10, 2010
    yes I did check all the resistor they hav e been replaced and the stk-110 have been replaced twice still the same issuses the tv will come on and work very seldom sometimes the green tube will flicker on the top half of the screen and the red and blue tube never come on than depends on the time all the tubes light up and you just have the color bars on the screen the pictures is great when it does come on before I started the picture was blurry - doubled - ghosting and now the picture is great and it will stay good until you shut it off is there any thing else you can tell me to check maybe caps voltage regulators or if I were to replace the whole board from Encompass might that take care of the problem or maybe I had two different problems because the picture seem fine when it does work Maybe a power supply issuse thank in advance for you response Brian
    Hey that sound like a plan I've herd of that before were one tube may be overdriving -- how much do I turn them and which way do i turn them --- can I put a volt meter some were and adjust all of them to the same voltage -- I do have a schematic for this tv on disc so I can look for location test points on that first if i need to - this tv is in a customers home so I'll wait to here from you on how to adjust them first before i go thank again Brain
  • Brian Lange Feb 24, 2010
    Back again no success adjusting the screen focus/drive I also resoldered all three yokes the ic on the yoke board look like it had some cold solder on them but no luck again. the customer can turn tv on and off and when the picture comes on it is great and it will run all day like that but as soon as it is shut off it will go back to the color bar thing or a green screen on the top half that flickers never the same screen comes on so than next time it just come up great it did have a convergence issue because before the picture was all double and discolored but as my previous post have described i did change out the convergence chips and resistors so I think i had two problems do you have any more to suggestions that i can try
    vdd
  • JVC Master
  • 5,138 Answers
Did you replace these resistors R842-2.2ohms,858-3.3ohms and CK these resistors R850- 2.2ohms,854.846- 1.5ohms and R862- 1.8ohms
Posted on Feb 05, 2010
  • 4 more comments
  • ladywinn
    ladywinn Feb 05, 2010
    Do you know How to Enter Service Menu for convergence alinement? There is 3 Different methods for JVC
  • ladywinn
    Encompass Parts Distrubtion has all the boards for this TV and Free Service manual you can print online from their website 1-800-638-3328. Go To their Website and type in your Model Number and it will list whatever they have for this TV.
  • ladywinn
    You really should have replaced the STK ICs with 150s the 110s are Bad Not to hold up and even the 120s are better then the 110s, When you go back to recheck Circuit CK for any Broken tracks they will Look solder but the track is broken and I order my ICs thru Mats Electronics 1-800-628-1118
    Let me tell you this also there is 2 types of setting convergence 1 is where the customer can aline
    minor adjustments the 2 convergence alinement is For Service Techicians Only, this is what I meant by Entering into Service Menu set by Factory, First Recheck everything you have done,also resolder all 3 yoke plugins after you have done this you may have to go to Factory alinement to correct convergence if you do I have information on How To Enter Service Mode.
  • ladywinn
    Another thing did you put heat sink silicon on Back Of New ICs?
  • ladywinn
    ladywinn Feb 10, 2010
    Remove front bottom panel cover it just pulls off and behind panel will be your Focus/Screen control Block adjust R/G/B screen drives to each TUBE R/G/B turn the GREEN down Control Block will have 3 controls on top for focus to each Tube and 3 controls under them are for Screen dives to brighten Tubes R/G/B
  • ladywinn
    ladywinn Feb 11, 2010
    With TV on and front panel removed so you can adjust Focus/Screen Drives For Each Tube
    Adjust Each Tube One at a Time Turn Green and Blue Off Then adjust Focus/S-Drive for Red Tube,Do this to Each Tube To adjust Green turn Red and Blue off,ETC....
    After you have Clear Picture for each Tube then you will want to adjust All 3 Tubes to where you have a Black and White Picture
    First Go To MENU TURN COLOR OFF After you have made adjustments and setting is a Black and White Picture,Adjust to as close to B-W as you can! Then Go Back To MENU and Turn Color Back ON. Clean off lenses to Top of each tube Also!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems you might have to change the board completely, also check the resistors as if they go bad you might have to do the repair again. Another reason could be the cold solder joints left out on the board and if the TV is too old then replacing the board completely will solve the issue, you can get a new one for around $65. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 04, 2010
  • Rylee Smith
    Rylee Smith Feb 05, 2010
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Feb 09, 2010
    Brian,
    This seems to be the issue with the voltage, I think its either not getting the voltage or maybe the power supply unit has gone bad, please click on this link to download the service manual and do the repair:
    JVC av-48wp30 Repair Manual
    JVC av-48wp30 Repair Manual-2
    Thanks
    Rylee
JVC AV-48WP30 , how to change convergence
First of all tools,requirement to do the work on the Convergence board to do changes the 2 STK convergence ICS and some or all it resistors.U have a soldering iron,desoldering pump or soldering wicks and solders?Don't?must buy to do desoldering and soldering?Tries Amazon.com to buy solders.Tries wesites like Tvrepairworld.com to buy the convergence kit to replaced ur self,and buy the soldering iron here it have the desoldering pump attach to the sodering iron it self.For video tutoring how to take out convergence board out of the tv and replacing the 2 STK covergence ICS and some or all it resistors.Might included in the buying of the convergence kit,not,Try You Tube type in convergence problems,will have video some body doing it.
Jun 07, 2010 | JVC AV-48WP30 48" Rear Projection...
AV-48WP30 - Is this a convergence board issue?
yes u r right that is the problem of convergence in your televisions.and it needs to be replaced to make it proper.
thanks.
Oct 29, 2008 | JVC AV-48WP30 48" Rear Projection...
My tv screen is showing a blue reflection
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 08, 2010 | JVC AV-48WP30 48" Rear Projection...
Picture is blurred and doubled
Convergence ICS is dead.Know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.To repair it ur self.The shop will cost u $300 dollars for parts and labors.
Jan 24, 2010 | JVC AV-48WP30 48" Rear Projection...
My 48'' jvc colorconvergence is out of wack how do I fix this what part needs to be replaced if any
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK-392-120 IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 23, 2009 | JVC AV-48WP30 48" Rear Projection...
I have a jvc av48wp30 tv and need a wire diagram
Looking the convergence board from the side of the resistors (The chips will be behind the resistors), you have from de left to right:
1.5 ohms, 150ohms, 220ohms, 2.2ohms, 3.3 ohms, 220ohms, 1.8ohms, 220ohms, 150ohms, 150ohms, 1.5ohms, and dispose horizontal in relation of the other resistors (the one near to the Ic is 2.2ohms and the other is 220ohms).
Hope this helps...
Feb 02, 2009 | JVC AV-48WP74 48" Rear Projection...
IC's for JVC AV-48WP30
you need two STK392-110 convergence ICs. You can get them at the following link with free instructions on how to replace them. They actually have the repair kit for your model which contains both convergence ICs and the convergence resistors.
Heres the link.
http://servicemanuals.vstore.ca/
Nov 16, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 tv(convergence)
This is a convergence board problem. Have a tech replace convergence IC's. The part no. starts with STK. If you are good in soldering and know how to test resistors, you can do it.
Jul 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Av-48wp30
If the convergence Ics and resistors are good its most likely related to the velocity boards that are attached to the Red CRT convergence yoke. Its the small board about half way up the neck of the CRT. If you need one let me know as I have a source for JVC boards for that model.
Jun 28, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
229 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
