Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The machine stops only at the water filling procedure.
    President:
  • 2,468 Answers
Replace the water/wash load fill size switch located on the control panel,it determines how much water you select for the load size
Posted on Feb 04, 2010
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
Water procedure stops every 20 sec.
check your water level fill switch located on the control panel,it uses atmospheric air pressure to determine when tub has enough water for load size,and the hose could be kinked to the switch or the contacts may be bad on the switch
Feb 04, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Washing machine keeps filling water doesnt shut off? whats wrong with it?
Hi and welcome to Fixya. The water vavle has a piece of foreign debris stcuk onthe internal diaphram. You can possibly clear this by removing one of the hoses at the wall connection. You will have to turn off both hoses at the wall initally. Place the removed hose into a bucket of water . Then turn on the one that is still connected to the wall. Place you machine on WARM wash and start filling the machine. GENTLY use the HANDLE of a screwdriver or hammer and tap the water valve at the hose connection. Let the water run for about 1 minute. Now stop the filling. Reverse on the wall hose connections and repeat the procedure above for the other hose.
If the problem does not clear you will have to change the water valve or take it apart and clean the diaphram.
Jan 24, 2010 | Kenmore 22422 Top Load Washer
Machine does not stop filling with water. Will
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Sep 30, 2009 | Washing Machines
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Water doesn't stop filling
If you turn power off to machine (or unplug) and washer continues to fill, you need to replace the water inlet valve. (the part the hoses connect to) If cutting power stops the water fill, you have a problem with the water level switch or the tubing leading to it.
Oct 28, 2008 | Whirlpool Washing Machines
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
