Question about Fellowes 59493 Keyboard
Not all keys on keyboard work properly
On the wireless keyboard, not all of the keys work properly, is this a function key accidently hit or what???
    Genius:
  • 1,554 Answers
Not likely, if the regular alphabet and numbers don't work then there is something sticky spilled under the keys.
you can remove the back and the membrane and wipe it clean. takes a bit of work.
Posted on Feb 20, 2008
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
Jun 02, 2012 | ASUS K40IN Notebook
How to turn on wireless on Acer 4551G
Look on both sides and in front of the laptop for the wireless switch.
Also once the wireless switch is turned on there arekeystrokes that can toggle the wireless on or off. Normally you wouldPress and Hold the FN function key located at the lower left of the keyboard,then hit the correct F1 thru F12 key that toggles the wireless. Thecorrect F1 thru F12 key to hit will have the wireless signal icon )))) on it.Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you togglethe wireless.
According to your manual Press and Hold the FN function key located at the lower left on the keyboard then hit the F3 key to turn your wireless on or off.
May 13, 2012 | Acer Computers & Internet
Emachines wireless not working
Try looking in the program list for the program that starts the wireless. Click Start/Programs and look for the program that drives the wireless and open it.
May 11, 2012 | E-Machines M5312 Notebook
Hi! All i have Amilo li2727 and using windows 7. my wireless net device doesnot want to turn on what must i do.
Normally there is a switch on the side or front that turns the wireless on. The FN function key located at the lower left portion of the keyboard toggles the wireless on and off if the switch is on. Normally you would Press and Hold the Fn function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it will have the icon of a tower with the wireless signal )))).
May 06, 2012 | Computers & Internet
Mouse pad stopped working
If you are referring to the "touch pad" on Laptop/notebook, if the touchpad on your laptop is not working and is unresponsive, it's not broken, you or someone else has accidently deactivated it with the function key.
Then you can try this,
Most laptops (if not all) come with a function key. The function key is labelled "Fn" and usually stands out from the rest - either the "Fn" is in a different color or the key as a whole. The function key works in conjunction with other keys on the keyboard especially the ones in the top row marked "F1" to "F12". The combination of function key with these keys lets you perform various tasks quickly such as shutting the screen, putting the computer in sleep mode, switching the wireless connection on and off etc.
By keeping the function key pressed and then hitting one of the keys ("F1" to "F12"), activates a task. You can activate and deactivate the touchpad by using the function key with the "F8" key.
Hope it helps.
Dec 11, 2010 | Computers & Internet
Cordless Keybaord - Some keys not functioning
Could be interference from a wireless device using the same frequency. Locate any other wireless keyboard/mice from the vacinity and try it again. Also, push the connect button on the bottom of the keyboard and see if that helps. Also make sure the base station of the keyboard is close enough to the keyboard/mouse.
Jun 25, 2010 | Logitech Wireless Access Duo Optical...
My hot keys dont work
Check for a button on your keyboard called FKey or function, hit this button and try again. if not hit the button again and try again.
See if this helps you
May 27, 2009 | Microsoft Wireless Optical Desktop 1000...
Wireless 1000 keyboard not supporting standard Windows F-keys
I had the same problem. I just could not get the "Alt-F4" function to work in a macro.
In the Macro Editor, in the lower center, you will see the "Z" actions. I realized I wanted the "Press and hold Z" function.
To get this, use "Inserting Special..." function to insert the Alt key stroke in the macro.
Then highlight the Alt in the Editor. Right Click and select "Split."
This will put the "Press and hold Z key" and "Release Z key" icons in the Editor.
What you want is the "Press and hold" function. Delete any other references the the Alt key.
Then enter the F4 key, and there you have it.
Hope this all makes sense to you.
Mar 25, 2009 | Microsoft Wireless Optical Desktop Pro...
2nd shift key on logitech keyboard (corded) no longer works
YOU HAVE TO GO INTO KEYBOARD AND FIND THE SETTINGS FOR KEYS IN CONTROL PANNEL . SET IT AS ENGLISH.
Feb 25, 2009 | Logitech Cordless Desktop EX110
Keypad not functioning properly...
Check to see if your shift, control, alt, or other modifier keys are stuck on your keyboard. These can cause your keyboard to act erratically. Also, if this is a wireless keyboard, you may need to change the batteries, as this can also cause a keyboard to act erratically.
May 14, 2008 | Acer Computers & Internet
Fellowes 59493 Keyboard Logo
216 people viewed this question
Top Fellowes Computers & Internet Experts
Gary Paul
Level 1 Expert
Are you a Fellowes Computer and Internet Expert? Answer questions, earn points and help others
