Question about Polaroid One Instant Camera
Removing old film putting in new
I want to remove the old film and put in new and I don't remember how
  • Anonymous Jun 11, 2008
    what way do you put the film in
  • 667 Answers
The latch to open should be on the side of the camera. The bottom front opens to allow you to remove the film pack
Posted on Feb 20, 2008
Do I need to remove the gearbox to replace the output shaft seal or can it be done by removing the shaft and putting a new seal in?
Year/make/model?? Most output shaft seals can be replaced with the transmission in the vehicle, Remove the driveshaft and pry out the old seal. Apply a thin film of grease to the lip of the new seal and carefully install it
Jan 20, 2016 | Cars & Trucks
Put new film in and the motor wouldn't stop running. samsung 1150
maybe the system of the motor its broken. you put the film but the system cilinder is broken and dont charge th film. you need to go to the technical service.
NEW Samsung Slim Zoom 1150 FILM Camera 38 115mm ZOOM LENS with DATA BACK
Dec 14, 2014 | Samsung Cameras
Acer 5315 blos password remove
If you have the old password: Go into the BIOS prior to booting your operating system. Go to the settings, put in the old password, and set the new password or leave it blank. You're done.
If you don't remember/previous owner set the password: There is usually a hardware jumper that, when removed, will allow you to deselect the use of a BIOS password. It is typically small, white, and plastic. This should be on the system board. It's different with every board, so I can't say exactly where it would be located on your machine.
Nov 10, 2012 | Acer Computers & Internet
Driver side mirror replacement
Instructions1.
    • 1
Remove thedoor panel. Refer to your Honda Accord repair manual for theinstructions in removing the door panel. Unhook the rods and connectors on theinside of the door panel and set it on the floor.
    • 2
Remove thefilm covering the access to the side mirror. It's difficult to avoid damaging thefilm while removing it so you will need to purchase a new piece of filmcovering when you buy a new side view mirror.
    • 3
Reachthrough the service hole into the mirror housing with a screwdriver. Loosen thescrew that holds the mirror. Twist the screw out with your hand.
    • 4
Reacharound the door and support the mirror with your other hand. Continue to twistthe screw out, then catch the mirror as it drops out when you remove the screwcompletely. Put the screw in a safe place so you don't lose it.
    • 5
Installthe new side view mirror by positioning it where the old mirror was. Insert thescrew you took out in Step 4 and twist it in with your hand. Insert ascrewdriver into the service hole to tighten the screw.
    • 6
Replacethe film covering that was damaged when you took out the old mirror. Push itinto place in the indentation on the door.
    • 7
Sit in thecar seat and adjust the mirror so you can use it properly.
Jul 06, 2012 | 2005 Honda Accord
My desk top system gets Off when I watch films only after the AMD processor is over heated.
i guess you mean the computer switches off when your watching films due to your AMD processor is overheating, if so best you order a replacement CPU Cooler usually around 10 pounds, just a matter of opening up the pc, removing the old cpu cooler by lifting the lever on it, and taking it off, remove the old thermal paste on the cpu and put new thermal paste on the cpu and attach the new cooler. also have a look at any other ways you can lower the temperature of the machine maybe thigns likes case fans etc.
Jun 16, 2012 | Computers & Internet
How do i replace motherboard
On a desktop it is easy because you don't have many parts to remove. A digital camera might help to remember where things go. Just remove the case and lay the laptop on it's side. Start unplugging the connections that run from the Power Supply to the motherboard and devices such as the hard drive and DvD Drive. You might have to remove the Power Supply, Hard Drive, Cd Drive, etc if they are in the way of getting the board out. There will either be screws that hold the motherboard to the case or there will be latches used to hold it to the case. Once removed, just lift the board out.
Remember to take your memory, CPU, Heatsink and CPU Fan off the old board and put them on the new one. You will need some Thermal Paste to apply a fresh coat on the Cpu and HeatSink to keep the board from overheating.
May 13, 2012 | Dell OptiPlex GX620 PC Desktop
I PUT IN A NEW BATTERY AND NO POWER
Brand new battery? Because I know for instance Canon ships some of their batteries fully discharged to minimize the risk of damage during shipping... If not, remove the battery and make sure the contact points on the door and in the bottom of the battery bay don't look twisted or damaged in any way.
Jul 12, 2011 | Minolta DYNAX 700Si AUTOFOCUS SLR CAMERA...
Not sure how to replce spark plug wires from the distributor need help please send info
change one spark wire at a time on the distributor.buy new set of spark plugs wires remove them from box.match old wires with new wires to use the correct length to each cylinder.now if you need to change distributor cap.mark location distributor cap.number tag plug wires on the distributor cap so you can remove plug wires on distributor cap so you can replace cap and rotor and put wires back on the distributor cap in correct place.remember change one plug wire at a time so you wont get confuse.
Apr 15, 2011 | 1992 Ford Tempo
Film winder jammed halfway throgh a film and i took that film out ( it expired anyway) and i tired to put new one in but i couldnt becuase the film winder wont move do i have to get this repaired?
Check all the batteries. Get fresh ones. If this is a manual, lever-action film advance and you have a camera with a spring-driven shutter you probably have a stripped sprocket and it needs new parts. If you have an electric shutter but there's one spring driven shutter speed as a backup, try that setting. If it is a totally motor driven advance, try checking the drive battery and clean the contacts. If the motor drive is removeable, take it off and try the lever-action advance. Remember, a group of AA cells are only as good as the weakest one. Good luck
Oct 29, 2009 | Photography
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Polaroid One Instant Camera Logo
141 people viewed this question
Top Polaroid Photography Experts
Myrddin R Emrys
Myrddin R Emrys
NOEL
NOEL
David Payne
David Payne
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
