Question about Amana ARS266ZBS Side by Side Refrigerator
Freezer won't stay consistently cold
I have a problem with my fridge. It started a few days ago when we noticed the freezer wasn't staying consistently below freezing. THen yesterday the in-door water dispenser stopped working, and today the fridge is not cooling. Lights are on and exhaust fan is running, but I have not heard the compressor kick in. I have unplugged it from the wall and cleaned the vents in the back and replugged it in but it still didn't cool. Any suggestions, tests, or analysis of the unit I can do to try and narrow dowwn the issue?
  • 4,793 Answers
Replace temp sensors in fridge and freezer (easier to do together) should work fine...
Posted on Feb 06, 2010
Fridge not staying cold and build up of ice on back piping
One of you fans is not running and causing the compressor to eventually making your compressor overheat and eventually shut off
Apr 14, 2013 | Refrigerators
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
Not getting cold anymore
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 13, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
Amana ARS266ZBS Side by Side Refrigerator Logo
411 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
