Question about Canon BP120 DH Calculator
Canon 1008 D paper won't feed
When I press "paper feed" it feeds but when I am calculating, it barely inches the paper up. I've cleaned with canned air and used alcohol swabs on the rollers that feed the paper Any ideas on what else to do?
  • ConstOffMgr Mar 11, 2008
    I've had this problem for a couple of months and gone through multiple rolls of paper but...In addition to what I mentioned I had already tried, I've since used wd-40 on roller/gears and replaced the paper. As a preventive measure, I followed marsrover's advice and took a straw (as it is flexible and thin enough to go through the paper feed mechanism) and made sure there weren't any objects inside. It's been working well for a week now and is working fine now. Thanks for the help!
I've tried all kinds of things, including re-installing the printer driver.
As a last ditch effort, I tried the old 'turn it off and turn it on' trick.
That worked for me.
Posted on Nov 02, 2016
  • 682 Answers
Check from free of any foregin object droped inside (pins -stapler-small pieces of torn paper.-reset the calculator(off and on).apply light grease on gears and check if it is fine ok. if not pass it to service center.
Posted on Mar 10, 2008
  • mohamed eltoni
    mohamed eltoni Mar 11, 2008
    DO NOT MENTION ALWAS AT YOUR SERVICE.
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
How do you load the paper on this adding machine?
    • 1 Cut the beginning of the roll of paper at a 45-degree angle with the scissors for better feeding into the Canon P23-DH V.
    • 2 Lift the paper arm up and slide the roll onto the paper arm. The cut edge of the paper should be feeding down from the outside of the roll.
    • 3 Insert the cut edge of the paper into the small **** at the back of the calculator.
    • 4 Press the feed button in the upper left area of the calculator's keyboard to feed the paper roll up through the calculator.
Jan 30, 2011 | Canon P23-DHV Calculator
I do not know how to put the tape into the calculator. There is a place in the back that it looks like it should go - I put it in there, press the advance paper key and nothing happens.
Push the roll of paper in until it will go in no further. On mine, it goes a bit more than a quarter of an inch. Once the paper is in all the way, press the Feed button until it shows at the top.
If it is still not feeding through, you may have a jam somewhere. Take the top of the paper area off and manually inspect the area to make sure nothing is out of place.
If you are still having problems, try feeding the paper in without the cover on. You can watch to see what is stopping it.
May 21, 2010 | Canon P170-DH Calculator
Ativa AT-P500 calculator; how do I put feed paper into it? Is there a manual for this?
I have the same problem (no manual) but solved it: the port of entry for the paper feed in located on the back, near the bottom. The top piece (where you tear the paper off) moves slightly to the back and can be removed. Feed the paper into the machine; pull out a few inches asnd cut the edges of the paper, about two inches back, into a "V" and feed this point into the slot just below the "ridge" and press "feed". Problem solved!
May 16, 2010 | Office Equipment & Supplies
How do you load paper into a canon p23-dh v
For loading paper into canon p23-dh v is to cut a piece of index card to the length of 3 inches and to the width of the paper you want to load. Tape evenly to the end of the paper roll and put into the ****, pushing gently in and at the same time pressing the 'Feed" button. It will immediately feed since it is firmer than the Poat-it paper.
Apr 26, 2010 | Canon P23-DH Calculator
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
How to feed paper into a canon palm size printing calculator?
There should be a small slot in the rear, gently feed the end into it while pressing the paper feed/advance button.
Sep 08, 2009 | Canon P1-DHV Calculator
Canon Calculator
Okay just figured this one out but on the back of the claculator there is a slip slid paper in that Press the feed key and allow the paper to feed through the claculator if it doesn't feed through push the paper in a little and hit the feed key again. It worked for me
Aug 18, 2008 | Canon P170-DH Calculator
Trouble Feeding Tape into Calculator
use a thin plastic card and put it on the load,maybe you have a paper on printer ,press feed and you vill clear all paper path
Feb 01, 2008 | Canon P170-DH Calculator
Canon BP120 DH Calculator Logo
577 people viewed this question
old marine
old marine
