Question about Dell Computers & Internet
WHEN I TURN IT ON NOTHING HAPPENS AND TWO LIGHTS ON FRONT KEEP FLASHING,DOES ANYONE KNOW WHY THIS IS
  • 14 more comments
  • jaystocken Feb 04, 2010
    Hi
    Thanks for the reply,no cannot hear or see anything I plug charger in and two lights on the front just keep flashing fast.any ideas on this it's doing me head in.
  • jaystocken Feb 09, 2010
    Hi
    Thanks for the reply.just added a new powerboard pcb and it's just the same.I put the charger in and the two lights just flash on and off.I'm going to buy one of the power supply tester that you told me about.If you any more ideas on this matter I would be grateful.
    Many Thanks
    Jay
  • jaystocken Feb 10, 2010
    Hi
    It's a Dell Latitude 100L laptop and model number is? don't know it's faded so I cannot see what it says.I've used two chargers on it and it does the same two lights just go on and off.
  • jaystocken Feb 11, 2010
    It's a new power circuit board I fitted.I don't know what else to try.
  • jaystocken Feb 12, 2010
    Hi
    I got the board of ebay off a working laptop it said.It goes at the top of the keyboard where the power button is,well in the middle.Don't know about the voltage it is I don't know.How can I check it?,I've downloaded the manual thanks.
    Hi
    No I cannot find the name for it from the manual as well.Just looked on the invoice for the name.Thanks for the help mate.
    Hi
    Yeah it's the one with the caps lock,number lock and another light on it.would this make the two lights on the front flash or something else?And do you think it's worth mending.
    Many Thanks
    Jay
    Hi
    Yes the power didn't come on the two lights just started flashing.I checked the screen and that's o.k so I'm lost.Sorry to keep asking you,I'm very grateful to your reply's.
    Many Thanks
    Jay
  • jaystocken Feb 16, 2010
    Hi
    I've just been fixing another laptop,it works then sometimes the fan stops and that does the same.The lights keep flashing.Do you think thats what happening to the Dell latitude 100L?Will get back to you when I,ve had a look at the wires.
    Many Thanks
    Jay
  • joecoolvette
    joecoolvette May 11, 2010
    Ah, now we're getting somewhere. Are you speaking of a circuit board that has a micro switch on it, and possibly some LED lights? The micro switch would go right under the Power On button. This would be called a Power Board, but is not essentially anything to do with providing, or converting power. Just has the Power On switch, (Micro switch), maybe LED lights, and a couple of connections. Was the original problem that the laptop didn't turn on, and you thought the Power On switch was bad?
  • joecoolvette
    Understandable Jay, and I commend you for your valiant effort. Where did this power circuit board come from, and what area in the laptop is it hooked up to? Is it connected to the DC Power Jack area on the motherboard? (DC-IN - DC Power Jack) What voltage is this power board putting out, and what voltage is coming in? Is the voltage, line voltage from your house? 110 or 220 volts? Or is the power board hooked up to the AC adapter? Were you able to download the PDF Service Manual for the Dell Latitude L100? Here is the Service Manual again. This time I managed not to foul up, and all you have to do is left-click on the link. After you click on the link you may not see anything happening for up to 30 seconds. The file should be downloading in the background. Watch the download progress bar, and let the file download all the way, before looking attempting to look through it. The file automatically opens, with the Bookmarks menu showing to the left side. Scroll the menu down until you see the heading - Bottom Assembly. Left-click on the + sign to the left of Bottom Assembly. (Or go to Page 26) Now scroll down to Page 33. Looking at the motherboard (System Board) in the illustration, can you give me a general area where you attached this Power Board?http://www.notebook-manuals.com/laptop-m... Here let's try it again with a better view using photos. After this PDF Service manual downloads, go to Page 54. Use the Zoom In, to enlarge the view. (+ sign at top)http://www.notebook-manuals.com/manuals/... Left-click on the green - Download DELL Latitiude L100 laptop manual, at the bottom/middle of the page.
  • joecoolvette
    To expound upon that last series of statements. It makes a difference, if we are talking about a supposed power module/power circuit board, or an AC adapter which converts Ac electricity to DC electricity, and at the right Voltage, and Amperage.
  • joecoolvette
    ????? With all due respect, and not wishing to incur your wrath Jay, I don't seem to find a power board, (Circuit Board), nor power module, for the Dell Latitude L100 in my Service Manual.http://www.notebook-manuals.com/laptop-m... Nor do I recall there being one. The DC Power Jack, (DC-IN), is soldered directly to the motherboard, and there is no cable leading from the DC Power Jack, (DC-IN), to a Power Module, nor power circuit board, and back to the motherboard. Granted I am getting on in years. May I ask where this is located? May I also ask how, and where you obtained it? Did you use Dell's automatic System Configuration Tool, and entered the Service Tag? Or is this a reference to an AC adapter? (Charger) Not trying to seem argumentative here, but we both have to be 'On the same page'.
  • joecoolvette
    Whoa, just a second there Jay. Are we talking about a Dell Desktop PC, or a laptop? Powerboard printed circuit board, and charger? The power supply tester I linked, is for a desktop computer's power supply. What is the computer manufacturer name, (Dell?), Model Name, and Model Number?
  • joecoolvette
    Yes, bad Power Supply. The Power On light, and the Harddrive activity light flash like that when they are indicating diagnostics. The diagnostic code is Bad Power Supply. You have a weak voltage power rail, in the power supply. You have enough power to turn on lights, maybe spin the fans a few times before they stop, BUT not enough power to turn the Processor on. (Not shouting) Information: 1) ALL the lights use less than 1 Watt of power. 2) EACH fan uses 2 to 3 Watts. (When they are spinning) 3) A typical Processor uses 55 to 125 WATTS. (Depends on what Processor it is, as to how much Wattage it uses) Replace the Power Supply, clean the inside of the computer out. Want to test the Power Supply to see if it is bad? The easiest way is to use a computer power supply tester. I recommend an Ultra power supply tester. (About $12 bucks)http://www.tigerdirect.com/applications/... You have to jump the Soft Power On of the power supply, to turn it on. want to know more? State so in a Comment. (Believe upper right corner of your page)
  • joecoolvette
    You're very welcome Jay, but so far I'm just asking questions, we're not out of the 'Deep End' yet. I also apologize for not catching, that it could have been that circuit board that has the Power On switch, and LED lights, as this is a usual design for most laptops. Just not a name used with all of them. My mind went to power TO the laptop, incorporating some sort of PCB, and not a PCB with a Power On switch. Yeah I know. Excuses, excuses, ha! (There are three LED lights on that power board. The Num Lock LED all the way to the left. The Caps Lock LED in the middle, and the Scroll Lock LED all the way to the right) To start anew. So I am to understand that you pressed the Power On button one day, and the laptop didn't come on, and there were two lights flashing in the front? Would this have been the Power On LED (Light) all the way to the Left side, and the Battery Indicator LED, all the way to the Right side? Also would like to know. (All electrical sources removed. Battery and AC adapter {Charger) With the AC adapter's plug inserted into the DC Power Jack on the laptop {DC-IN}, can you wiggle the plug, and it feels as though the DC Power Jack is loose? Before you have tried powering on the laptop, have you made sure the battery is charged up all the way? Using at least three hours, or more, to charge the battery? Is the laptop dirty inside? This can be viewed through the Air Intake Duct, with a flashlight. (Round air vent on the bottom of the laptop. Below the Battery Bay, and towards the back right corner) Also would like to know if that power board has wires with a connector, or has a flat Flex cable with a connector. (Flex cable is a thin, flat, ribbon. Has several wires that are side by side, and are coated with insulation, and installed in one flat ribbon) Could be a problem with the connector of that flat Flex cable, if so. Not making a good contact, and/or not keeping a good contact. Could be a problem with the DC Power Jack being broken, or it's solder joints to the motherboard are cracked, and not making a good contact. Could be the battery charging circuit, and it is faulty. (Sensor circuit to sense when the battery needs a trickle charge, and/or the laptop is going to run strictly off of the AC adapter, or strictly off of the battery) Got to climb the mountain one step, at a time. Can't jump over it.
    Problem Solver:
  • 7 Answers
Can you hear the hard drive spinning? Can you see or hear any fans working?
It may be that the power on your pc has stopped working Try a new lead into the pc first as it may be the cable..
Posted on Feb 04, 2010
  • wornoutmum Feb 04, 2010
    Did anything happen with the pc prior to this happening? Did you install any new hardware? How old is the pc? Have you a graphic card in there?
2001 Subaru outback limited security light flashing rapidly!!?
Reset the system by removing both battery terminals
Hold the positive and negative together for 30 seconds
The. Reinstall both terminals
The system will re learn for the next 10 miles or so
If it happens again to the light
We will have to try another approach
Best of luck
Feb 22, 2015 | 2001 Subaru Outback
All lights flash - machine does not work
the machine is unstable as in you have to big of a load in or uneven load it happened to me when i put really heavy bath mats.
Jul 10, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Wont turn on, power light just flashes and nothing happens
batteries are dead,or not in properly.if not. only use energizer lithium batteries.others burn out very fast,hope i was helpful.
Apr 14, 2009 | Samsung Digimax S500 Digital Camera
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
AEG Lavamat E1050 End light blinks 5 times.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
(Companies just want you to dump the machine & buy another, its keeps them in business)
Jun 01, 2008 | AEG Lavamat W1050 Front Load Washer
Maxim lcd tv stays on standby.
got the same here, turned it off via on/off button, then the big lightning storm happened ,next morning same as the rest, anyone got a clue how to fix it, ive opened it up but even thats beyond me.
Ant
Mar 26, 2008 | Televison & Video
Green light
check horizontal o/p&osc
Mar 11, 2008 | Televison & Video
Red light flashing-not reading ink cartridge
I have the same proble, except that the red light keeps flashing and nothing happens...
Oct 15, 2007 | HP PhotoSmart 7660 InkJet Printer
Computers & Internet Logo
189 people viewed this question
Alun Cox
