Question about Wagan 2012 5000 Watt Dc Ac Power Inverter 4 Outlet
Hi I have a Wagan 2012 5000watt inverter and it has a panel of four outlets at 1500 watts each but it also has Hard Wire AC Terminals, my question is are the Hard Wire AC Terminals capible of the full 5000watts,
    Guru:
  • 290 Answers
I do not think they are but i will like you to refer to your invert manual
Posted on Feb 25, 2010
I have a 3000 watt inverter,with 3 plug in outlet..how much power do I get from 1 outlet..this equipment is hook to 6 12 volt battery charge by a 60amp controller and 3 solar panel of 265watt each???
You didn't mention what make or model of inverter. Lets assume you are in the USA and your inverter has standard the US 15 Amp three pin 125V NEMA 5-15 AC outlets. based simply on that you would have a max of 125 x 15 = 1875 watts per outlet.
Dec 07, 2016 | Solar Electronics - Others
Cobra 1500w inverter runs for 4 min. and then shuts off with the code OPC.
Hi
Is the code OCP?
If it is not the code appearing in the display, then it is not a user code but O does refer to an over tollerance situation and L refers to an under tollerance situation can you clarify?
Oct 30, 2013 | Cobra Electronics 1500 Watt Triple-Outlet...
Installing a 1500 watt inverter on a frieghtliner cascadia
You dont want to install directly to the battery as the battery will constantly produce energy draining the battery instead install it to the yellow ignition wire usually accessable under the dash so as it only runs when the vehicle is on You can also usually locate the ignition at the fuse panel
May 20, 2012 | Cobra Electronics 1500 Watt Triple-Outlet...
This is a Wagan 2003-6 400Watt with USB DC to AC Inverter. Worked great for almost a year. Recently fan was varying in speed under load. Then finally blew my vehicle cigarette lighter receptacle fuse. ...
A few thoughts on this. With the transistors, if these are a darlington style of transistor, it might show a short on a good transistor. The USB "transistor" is a voltage regulator, 12v to 5volts dc. With the inverter input, some inverters use a diode in the input to protect against connecting the inverter by reversed leads. This diode might be shorted and be causing your problem. If it comes to changing the transistors, it might be cheaper in the long run to buy a new inverter. The transistors might be problematic and might not be the only thing problematic. Experience here talking!
Feb 05, 2011 | Wagan 20036 400 Watt Power Inverter Corp
Hi. I keep blowing inverters. I had a 1200 watt Coleman that went out while running a fan. Just installed a Cobra 800w inverter in my Dodge Ram under the center console. I had it wired to an outlet on my...
Well without knowing exactly how you wired it, it is hard to say what happened. A little diagram would help. But, with nothing plugged into the inverter, the wires must have been shorted. What size wire are you using? If you have an 800W inverter, the amperage on the secondary, (120V) side is only about 6.5 amps. So if you ran 14 ga wire (smallest you should use on 120V ) that should be fine for the 120V circuit. Do not connect any of these wires to anything but your remote receptacle. Now for the primary. Notice how large the terminals are on the supply side, if you have an 800W load @ 12V that would be approx 66amps. Therefore you should have #4 or #6 copper wire going from the battery to the inverter. This wire must be fused, and I'd fuse it with a 60A fuse. You can buy nice fuse holders like they use on amplifiers that connect right to your battery. Now on the 1200W unit, you can imagine the difference. The secondary would be 10amps and the primary would be a whopping 100A. Even if you have a large alternator, I'm sure it is not rated at 100 amps continuously.
Oct 19, 2010 | Duracell Portable Digital Inverter - 800w...
..phone number of customer care required.invertor
http://www.wagan.com/index.php?option=com_content&view=article&id=144&Itemid=104
Jun 21, 2010 | Wagan 2382 Smart Ac USB 120 Watt Invertor...
How many batteries do I need to run a coleman 1500 watt power inverter
It would depend on the load being driven by the inverter (which would determine the current drawn by the inverter), the capacity of the batteries and the shutdown voltage of the inverter.
Oct 01, 2008 | Statpower PW-1750 Triple Outlet 1750 Watt...
Power inverter
hi you have two resens for this the first is your alternator is defective and your inverter can't not read the good isotope frequencies and the deep you lisent it's wrong isotope
the other one, you have two transistor attach to a cooler, these are scrap, this is those hoo create the isotope (hz) and hosting high ac current
so hi hope i help you bye
Sep 27, 2008 | Lenmar 1000W Power Inverter
Wagan 2012 5000 Watt Dc Ac Power Inverter 4 Outlet Logo
204 people viewed this question
Top Wagan Electronics - Others Experts
Are you a Wagan Electronics - Other Expert? Answer questions, earn points and help others
