Question about GS NORTH AMERICA: PRESSURE BALANCE VALVES - 1301-0 - Chrome
Im trying to find the pressure rating on these valves?
    Sniper:
  • 82 Answers
The datasheet at this site implies that it has been tested to 100 PSI .. http://www.gsnorthamerica.com/1510.pdf
If you go to the main gsnorthamerica website (www.gsnorthamerica.com) other spec sheets and install guides are available as you dont mention the exact valve type.
If this helps please leave feedback, if not let me know and I'll try and help some more!
Posted on Feb 04, 2010
Good afternoon. It starts and builds pressure unit it pops the safety valve. The engine rpms do kick down.
-The valve is not work properly or deffect. Need to be replace.
-It should turn off when it reach to the pressure you set for.
It's not safe to run.
Goos Luck.
Mai Lor
Apr 25, 2016 | Air Tools & Compressors
Pressure valve close to heater hose spewing fluid while driving
Not sure what pressure valve your talking about a picture would sure help im thinking it could be the water pump or thermostat if it's what the heater hose connects to on the engine it's the water pump and needs changing Id Google the " Valve" in question or utube and see what the proper name for said valve is and then you will have info needed to make repair!! Im sure others have had similar problem?
Mar 15, 2015 | 2004 Dodge Stratus
High pressure wont shuy off
do you mean it keeps trying to build pressure even when you release the trigger on your wand???that is a problem with your unloader....also checkout your shutter valve and replace the oring on it. You will need the diagram here to know what parts Im talking about Pump Breakdowns and you can order parts here Pressure washer parts catalog quick links Pressure Washers High Pressure...
Jul 19, 2014 | Annovi Reverberi 2400 Ar Pressure Washer...
Does not shut off and the safety valve went off
Your problem dependents on when the safety valve is opening. If the safety valve is opening before the tank reaches its rated high pressure level, usually 130 to 150 psi, the spring in the valve is weak or broken; replace the safety valve. If the tank pressure is going over the rated high pressure level, the pressure switch isn't turning the motor off when it should; replace the pressure swtich.
Nov 25, 2012 | Stanley Air Tools & Compressors
My kobalt air compressor model#215914 won't stop running is it suppose's do that?
All compressors run up to their rated high pressure level, usually listed on the data plate on the compressor or in the manual, then the pressure regulator turns them off. If your compressor is not shutting off it is either not getting to the pressure it takes to get the pressure regulator to turn it off or the pressure regulator is broke and won't turn the motor off. To check which, turn the compressor on and watch the guage that shows tank pressure. If the pressure rises then stops at a level below the rated pressure for your compressor and the motor continues to run, you have a leak somewhere. It could be the tank drain valve, the lines from the pump to the tank, the valve plate or in the piston cylinder area. If the pressure rises more than ten psi above the rating for your tank, your pressure regulator is broke or possibly set too high. If you know how, you can try lowering the shutoff point to see if that fixes it but you're usually better off replacing the regulator.
May 09, 2012 | Air Tools & Compressors
I have a Bryant 561030 the low Pressure is 68PSI and the head pressure is 350+ I'm not getting any cooling i cleaned the condenser but it still giving me the same + pressure
Have you changed the inside filter or cleaned the inside coil?
Also if you have a amp meter check the amps the compressor is pulling compare it to the nameplate rating.If the amps are high you may have a bad compressor.
Im assuming your running r22.You may also have a bad capillary tube or expansion valve depending on what this unit is using.
Jul 18, 2011 | Heating & Cooling
Slow leak at base pressure relief valve
Sorry to read about your problem, I hope this helps you out.
They go bad, rubber inside gets old, just replace the valve. turn off water first
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Rheem Water Heater Pressure Relief Valve
2000 ford taurus low end ac valve
please rate as fixed if this helps you.
The low pressure service gauge port valve is located on the evaporator to accumulator/drier suction line.
The evaporator to accumulator/drier suction line contains low pressure refrigerant gas and is equipped with a serviceable low pressure A/C charge valve port.
Apr 28, 2009 | 2000 Ford Taurus
Pressure upto max nearly im my bolier
You don't say what kind of boiler this is but I'm going to guess that it is a hot water boiler.  If so, you have a combination valve which adjusts the water by pressure and bleeds off excess.  These valves do get corroded and dirty.  Shut down the boiler, shut off the feed water valve.  Replace the valve assembly.  Do not try to adjust these things.  Your new valve should maintain about 15 psi.
Dec 19, 2008 | Heating & Cooling
Pressure low.
how do you know the pressure (im guessing you mean cylinder pressure) is low? this can be caused by : Leaking or bent valves from a broken t-belt or skipped timing (from loose t-belt), and bad piston rings how many miles on this motor and does it run at all? you should check your timing belt and be sure the timing is set correctly please let me know and be sure to rate this solution -jeff
Aug 29, 2008 | 1994 Honda Civic
GS NORTH AMERICA: PRESSURE BALANCE VALVES - 1301-0 - Chrome Logo
59 people viewed this question
Top Gs North America Plumbing Experts
Donni Steen
Tom Chichester
Are you a Gs North America Plumbing Expert? Answer questions, earn points and help others
