Question about Rio Go Video DDV9556 Dual Deck VCR
The left side deck (Deck 1) ejects the tape on starting
It tries to pay it but after  second or two it shuts down and ejects.. So now I am using just the right side which is functioning fine.. for all features... thanks ...ben
  • 579 Answers
Just the usual problem of needing the rubber belts replaced.
Take the top cover off and watch the mechanism move, usually you can see what the problem is if you get to know its motion. Best if you learn this before it develops a problem of course.
Buy a kit of belts for your model from all kinds of sites on the net and install them yourself if you are handy with delicate mechanisms.
Hope ya fix it!
Posted on Feb 23, 2008
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Videotape dubbing deck dead
1. Check to see if a tape is jammed inside (see 284 Extract a Jammed Videotape).
2. Try changing the video input and/or output source. Many VCRs have two ways to receive and send a video signal (coaxial and video direct). If that works, try changing the cable for the other method to see whether you need a new cable.
3. Clean tape heads (see How to Clean VCR Heads).
4. Open VCR and inspect any belts that are accessible (see 284 Extract a Jammed Videotape). A drive belt may be broken or loose.
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads.
I would suggest that you also replace the Capstan Pinch Roller.
Goodluck..
Feb 17, 2008 | Rio Go Video DDV9556 Dual Deck VCR
Tape player keeps automatically switching between
In my experience this is often down to a cog or other maniacal device in the player that has suffered some damage. As it is playing the fault causes a switch, which should not happen, and then leads to a chain reaction to the eject.
Jan 04, 2018 | JVC TD-W354 Single Cassette Deck
SONY TC-WR550z dual tape deck eats tape and doors won't open I hadn't used this unit in 5 year (it's 13 or 14 years old), and before it worked fine. I went to use it again last month (MJ "Thriller" tape!)...
I don't know anything about the "eats tapes". You can take out your tape fairly easily thought. All you need to do is
unscrew screws on the left and right side of unit
remove the cover
use a flat head screw driver to gently push down on a white lever on the side of the drive mechanism while pushing the eject button
Sep 13, 2009 | Sony TC-WR565RM Single Cassette Deck
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Tape Deck does not recognize tape adapter. Does not eject.
Just an idea .. In the past I have removed hungry decks from my cars. A lot easier to work on / dismantle than in dash. gently remove the casing and you should find the tape deck a separate component within the whole unit.Hook up via alligater clips to battery to power up and alligater clips to a speaker lead to hear. saves a lot of stress. Usually done for chewwed up and swallowed tape. results are good, surprisingly.
Cheers !
ozzy
Feb 21, 2009 | 1996 Ford Taurus
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Tape stuck inside
there is screws on the unit when the unit goes into rewind mode disconnect from mains and unscrew unit first check to see if the screws are scurity type haveng a hex or star shape on them if either then take to video and tv repair shop and explain that you need to remove a tape from unit you may have to pay for a small fee for it to be removed this part is all i can give but if you can remove screws yourself then locate the motor for tape ejet and load and manualy wind till tape is removed good luck
Aug 06, 2007 | Sony DSR-11 DV / Mini DV VCR
Rio Go Video DDV9556 Dual Deck VCR Logo
61 people viewed this question
Top Rio Televison & Video Experts
Rommel Balcita
Jaime Hernandez
JOHN TOPLISS
Are you a Rio Televison and Video Expert? Answer questions, earn points and help others
