Kenmore Washer - Makes sound, but does not spin
My Kenmore Washer makes sound (as if the motor is working), but it is not spinning the spindle (in other works, looks like the motor is working, but the spindle is not rotating). The water flow is fine. And also, the sound is little bit high and has some odd sound.
Any suggestions / Guidance?
Thank you very very much.
Sam
  • 5,911 Answers
More than likely this is a broken motor coupling. If the washer does not agitate or spin, but will STILL drain, the likely culprit is a broken motor coupling. You may also hear a loud rattling sound as the drive motor engages, but the tub no longer spins. That could be the "grinding" noise you hear. Whirlpool uses a motor coupling in the place of a drive belt. It is located between the drive motor and and gearcase (transmission). This configuration is known as a "direct-drive" system. It is common for the coupler to wear out with age and break. Newer versions of this coupler are more resilient and resist breakage. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for the improved motor coupling is included in the link I provided. The average cost is about $10 - $15. You can purchase replacements at any of the following webistes:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. If you do not wish to order on line, take the part number provided and go to your nearest appliance parts retailer. This is a common part they should have in their in-store inventory.
If you have questions, or if the symptoms I describe do not match what you are experiencing, please post back and let me know. I hope this helps you.
Posted on Feb 04, 2010
Testimonial: "Sorry, I forgot to thank you on this. This help me fix the problem at that time. I replaced the coupler successfully same day."
What makes the drum spin?
There is a motor on the bottom. You can see it if you lay the machine down. The motor has a belt that attaches to a transmission. The belt could be loose or off. The transmission could be bad, or the spindle into the drum is stripped.
Jun 12, 2014 | Kenmore 22422 Top Load Washer
It has stopped spinning. Still makes a noise that
sounds like the motor coupling has broken,anytime a washer gets out of balance it usually breaks the coupling!
Jan 09, 2010 | Kenmore Elite 45986 Front Load Washer
MY WASHER WILL NOT SPIN. iT MAKES A LOUD BUZZING
Sounds like a broken motor coupler for sure, the motor shaft will still spin the drain pump, but drive between the motor and transmission is lost. Part# 285753A. Have fun. If you need breakdown info let me know.
Dec 30, 2009 | Kenmore 22422 Top Load Washer
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Not draining and spins a little but makes a whirring sound
you need to clean your pump something in your pump is causing your motor to work harder
Dec 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer 90 series Washer will not spin
  • Check that the water supply valves are turned on
  • Inspect the filter screens
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve.
  • Test the motor
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer won't spin
ok " sounds like motor belts need replaceing, that smell is the loose belt rubbing against the motor pully.
Jan 01, 2008 | Kenmore 12502 Top Load Washer
Washer won't spin.
Sounds like a broken motor coupler. Is it draining? you can get the tutorial for replacing the motor coupler at www.shop.washermd.com Dave
Dec 10, 2007 | Kenmore 15944 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
