Question about Canon imageRUNNER 5570 Copier
On our 5070 machine it ran out of staples. When
On our 5070 machine it ran out of staples. When the staples were replaced they were put in upside down. How do I open the staple case and put the staples in properly?
  • 58 Answers
Take out the staple cartridge and in the clear plastic you will see the arrow engraved the white box also has a arrow these two have to overlap each other to open the case it has two little tabs at the bottom press them in might wanna use a pen or something and the top part will pop up just pull it out
Posted on Feb 10, 2010
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
I have been trying to load the stapler but when I put the cartrage back into the unit it starts making a weird noise and the the screen still shows load staples so I do not know whether I am doing...
Remove the stapler cartridge and look on the clear plastic part of the cartridge. Do you see the arrow pointing towards the puncher side of the cartridge. The arrow of the replacement staples should line up. I've had customers put the staples in upside down before. The only problem is that you then have to take the staple cartridge apart to remove these staples and reuse them. . You just have to release the 4 clips at the bottom and carefully remove the piece. Be careful of the black arm that hangs down when the cartridge is held in the up position. When replacing the bottom back on, the orientation of this arm is important ( upside down or right side up) . This tells the copier that the staples are out. Hope this helps.
Jan 13, 2011 | Canon imageRUNNER 5570 Copier
Our copier ran out of staples, where do i put more in
STAPLES WILL GO IN THE FINISHER UNIT.OPEN THE COVER AND REMOVE THE STAPLE UNIT AND PUT NEW STAPLE PINS
Jan 07, 2011 | Sharp AR-M350U Copier
Do not know how to put staples in my powershot pro
Howdy, on that model, you withdraw the plunger and turn the stapler upside down and lay the staples on the track (on the botton of stapler, not in the back) with the points facing up. When you replace the plunger, it holds them in place. I really like the reverse stapling action on that model, easier on my wrist. Hope this helps some:)
Farmerbear
Aug 30, 2010 | Powershot Tool Company Cobra 8000 Forward...
I cannot figure out how to load an Arrow T50P staple gun
Turn it upside down. On the end opposite where the staple comes out look for a tab on each side you squeeze to release the staple holder, the staples go in to this holder upside down as well, just push it back in until the releases catch and hold it in. Hope this helps.
Jun 17, 2010 | Arrow T50P ARROW STAPLE GUN
Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
Sep 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
How do I load this Stanley Staple Shooter Light Duty?
This doesn't load like normal staple guns. Go to the end of the stapler and pull out the locking device with the spring on it. Then turn the staple gun upside down so you're looking at the bottom of the gun. See, there is now a little channel exposed. Drop the staples in this little channel with the points of the staples pointing towards you. Keep the staple gun upside down and reinsert the locking device which will compress the staples. PRESTO! Ready to use.
Aug 26, 2009 | Powerfast Stanley TR110 Light-Duty Staple...
Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
May 10, 2009 | Tools & Hardware - Others
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
Loading staples
First turn the staple gun upside down, like you were going to staple the ceiling. Then grip the 2 black circles and pull out (slightly up helps). Then place the staples upside down in the groove you just uncovered (in the stapler, not the part you pulled out), push that part back in, and you're done!
Dec 02, 2007 | Black & Decker 5700 Powershot Forward...
Canon imageRUNNER 5570 Copier Logo
382 people viewed this question
old marine
old marine
