Question about Electrolux ELD-726300 AOFP201RU Blast ChillerFreezer Half Size reach in (20) 12""x20""x2 and a half"" pan capac...
I purchased a electrolux model # aofp201ru I need
I purchased a electrolux model # aofp201ru I need to know what size condsening unit I need, I am remoting the unit on the roof.I also need to get the wiring digram, and any other useful literature on using this unit. Thank Robert
    President:
  • 1,515 Answers
Hi Robert, I repair and install commercial refrigeration and may be of help to you. You need to determine the size of the evaporator coil so you can match up the condensing unit for it. I don't no the voltage that it is, but this makes no difference, just make sure the condensing unit is the same. The condensing unit comes as a package, compressor, defrost clock, everything you need. All you need to do is run your copper, suction, and discharge lines and electrical through the roof and tie in at the evaporator. Install your driers and site glass at roof on your liquid line going back to the compressor.Your new condensing unit will have your power lines out, marked for you to tie into. You will need to set a disconnect box at the condenser. I am not sure what this box has to run, evaporator fans and a thermostat. All other controls will be with condensing unit. Since you are setting this up simular to a walk-in box, if the box didn't come with a txv, ( Expansion valve) you will need the right one for the evaporator to match. A liquid line solenoid valve at the evaporator to start and pump down the unit when the stat is satisfied. It will be wired into the thermostat down below. When you go to the parts house take all of your model, serial, product numbers with you and cubic inches as well. They will fiqure out the size you will need and what you will need. Wiring is very easy doing what you are doing, but if you feel you need a diagram, ask them and they will come up with a drawing for you to work from. They are very helpful if you are getting this condensing unit from a refrigeration parts wholesale house. Thay will tell you exactly what you will need to split this box. I hope I haven't confused you. It is basically very easy, just take your time and you can do this. Best of luck,
Shastalaker7
Posted on Feb 04, 2010
My Electrolux microwave model E30mh65gps only has on spot to mount it to the cabinet.
Contact your manufacturer or dealer where you purchased the unit. You should be able to purchase mounting brackets to fit almost any design or install situation for safety and liability reasons.
Sep 19, 2012 | Electrolux E30MH65GPS Microwave Oven
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
May 01, 2011 | Electrolux Microwave Ovens
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Our vac unit is 1 1/2 yrs old. It will not shut off, I've tryed your problem solver by hitting the unit with a hammer. I'm an electrician I was surprise by this advice but never the less I did it and it...
Your machine is still under warranty if you purchased it new (5 years). Take it to the shop you purchased it from (Aerus Electrolux), or call them for free pick up, and ask them to repair it. The boards do go bad occassionally. It could also be the switch, but can't be sure without taking a look at it and testing it.
http://www.aerushome.com/storelocator/
The warranty is good only if the vacuum was purchased from an authorized Aerus Electrolux store or representative. Take your copy of the contract in with you.
Nov 25, 2010 | Electrolux Centralux Vacuum
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Mar 12, 2009 | Electrolux AWF1235 Front Load Washer
I am doing an inventory and need to know what type of refrigerant would have been used in an Electrolux window AC unit. No model or serial number, but probably manufactured in 1990s.
MOST OF THESE WINDOW UNITS WERE R12 UNITS YOU CAN LOOK INSIDE CABINET AND SOMEWHERE IT SHOULD HAVE A FILL CHART TELLING HOW MUCH AND WHAT TYPE , THIS IS THE ONLY WAY TO BE 100% . BECAUSE SOME OF THE LATER MODELS USED 134 ,OR 134A DO NOT MIX REFRIGERANTS
Nov 24, 2008 | Electrolux Heating & Cooling
Open Questions:
See all Electrolux ELD-726300 AOFP201RU Blast Questions
Electrolux ELD-726300 AOFP201RU Blast ChillerFreezer Half Size reach in (20) 12""x20""x2 and a half"" pan capac... Logo
75 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
