Question about Braun KSM 2 Electric Blades Grinder
Braun KSM1 XXU coffee grinder stuck 'ON'
For no apparent reason, my (older) coffee grinder today simply remained ON when I released the 'grind' button. I see no easy way in to the working parts to de-clog or clean out the stuck switch. The problem appears not to be outside the casing.
How do I get access without damaging the grinder. I love it.
Model No: 4024 755854 KSM1 XXU 120V a.c. 40-60 cps/1.1 amps
Made in West Germany!
  • esadok Sep 25, 2008
    I had a similar problem. Cleaned out the excess coffee inside the grinder using an old tooth brush. Unfortunately, I dislodges a little plastic piece that is part of the on/off switch mechanism.
    Does anyone have a parts diagram showing how this on/off swich is assembled?
  • 4 Answers
The little plastic piece is part of the spring tension for one motor brush. It has been re-installed. I no longer need any assistance.
Posted on Sep 25, 2008
    The base of the coffee grinder can be removed and the bottom of the coffee grinder cleaned out with an old tooth brish.
    Procedure:
    1) Mark the orientation of the base and the body of the grinder. Place a piece of masking tape on the body (near the base) and another piece of masking tape on the base. Using a pencil or pen to draw a line across the two pieces of tape. This will show how the base and body must be re-assembled after the cleaning is done.
    2) Using a Philips screwdriver, remove the two screws on the bottom of the coffee grinder.
    3) Carefully pull back the base to reveal the motor and on/off switch (attached to a plastic piece).
    3a) The plastic piece pushes against a wire on the motor body. The wire makes contact with one of the motor wires. It is a simple mechanical operation. There is no physical "on/off" switch as one would expect to see.
    4) Use an old tooth brush to brush out loose coffee that has been deposited inside the grinder.
    5) Put the base back onto the body, aligning the two pencil/pen marks.
    6) Screw back the two Philips screws.
    7) Try the grinder to see if this cleaning out allowed the plastic piece (in the switch mechanism) to move freely down and up, to turn "on" and turn "off" the grinder.
    8) If the above does not work, then the coffee grinder has to be dis-assembled more completely to gain access to the plastic piece that is part of the mechanical switch assembly.
  • C Kali
    C Kali Dec 03, 2012
    Hi, is there anyway to replace this part? I have an old KSM 1 with the internal "off/on" plastic part which snapped so I cannot operate it any longer when I twist the cap.
How to remove the old blade and replace with a new one on its wayof a Braun coffee grinder Type KSM1
have you searched for the user manual online or the technical manual for that model ?
Mar 06, 2017 | Braun Coffee Makers & Espresso Machines
Grinder blocked Saeco Caffe Charisma
If the problem is only just stuck then you should try to rutn the gringing adjustment to more gross grinding and first try to remove all remain coffee beans from grinder, with the use of avacuum cleaner try to clean everything from the grinder beans and grined coffee. Then try to make a coffee if it continue to be stuck turn for more gross coffee grinding clean with vacuum and try again is the grinder is only stuck then this will work if after all these the grinder does not turn then you will need to remove it and also you might need to replace it.
May 10, 2012 | Saeco Caffe Charisma Espresso Machine
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
Does not grind beans
This can be caused from a broken by a brken grinder motor or even broken grinder sensor.
However this can be cased by a stuck grinder from grinded coffee to the grinder bledes. So you try from the last posible problem by removing all the coffee beans from the machine and by the use of a vacum cleaner try to **** all the remainings both beans and grinded coffee. If you can remove the top panel then you will have access more direct to the grinder and by the use of painting brush and vacum cleaner you will be able to clean the grinding blades mere intesive. Try to rotate the blade manualy to be sure that they can run after the cleaning.
So now you will be able to add some beans and try the machine again. If the probelm remains then you will need a new motor.
Good luck.
Please emeber to vote for this answer
Mar 13, 2010 | Saeco Easy Espresso Machine
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 21, 2009 | Gaggia Paros Espresso Machine
How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Jul 13, 2009 | Braun KSM 2 Electric Blades Grinder
Blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Dec 16, 2007 | Braun KSM 2 Electric Blades Grinder
Braun KSM 2 Electric Blades Grinder Logo
1,740 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
ellipse0904
Level 1 Expert
Jim Thurston
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
